Startup GuideThank you for choosing TeeChart .NET Professional Edition. What follows is a number of useful links and explanations on the recommended usage of TeeChart.Extensive documentation and tutorials for the use of the TeeChart API can be found at the Steema documentation site. Steema's online forums at support.steema.com are read-only for evaluation-version users and read-write for registered-version users. Steema's github page contains a number of demonstration applications which were designed to work with TeeChart Professional and which can be cloned or downloaded from here and here. TeeChart Professional can also run the demonstration applications produced for TeeChart Standard and which can be cloned or downloaded from here. How to deliver the TeeChart License to a development machineThe TeeChart Professional edition uses a small app called TeeCalc_Lic to deliver the TeeChart License to a development machine.The following tutorials in gif format are designed to help with the details of how to use the app in differenct circumstances.
How to use the TeeCalc_Lic app to activate the TeeChart.licenses file on a development machine without an active connection to the internet.
Use URL: https://www.steema.com/linkIn/licactivate
How to use the TeeCalc_Lic app to deactivate the TeeChart.licenses file on a development machine without an active connection to the internet.
Use URL: https://www.steema.com/linkIn/licdeactivate How to install/use the TeeChart LicenseThe TeeChart Professional edition uses a license file to activate the evaluation version, removing the watermark displayed on evaluation version charts.The following tutorials in gif format are designed to help with some common tasks relating to the license. Choose a platform and view the tutorials 'How-to' and more. Checking your license informationPlease follow this link to check your license information.How to add TeeChart .NET for Professional to a Windows Form design surfaceThe TeeChart.licenses file should be installed as an embedded resource in your Windows Form project.How to enable the TeeChart.licenses file for a Silverlight applicationThe TeeChart.licenses file should be installed as a content resource in your Silverlight project and a reference to DH.Scrypt should be added. |
