Right now I am creating a chart showing up to 4 category types (income, expense, equity and other). As of now, I am looping the same code using four different TQueries in a for-do loop. The only difference between each SQL statement is whether the transaction belongs to one of the four series or 'category types'.
1. Is it possible to 'filter' one query to create different series with one query?
2. or is possible to 'lock in the values after each SQL execute and still use 1 component?
Creating a 4 Series bar chart
Re: Creating a 4 Series bar chart
I understand you have something like:
And you would like to do something like:
You should use the ValueSource property in the series valuelists to assign a column from the query.
Here it is an example using a single query call to populate two series.
for i:=0 to 3 do
if i=0 then
SQL:='*** income ***';
Series1.DataSource:=Query1;
end
else if i=1 then
SQL:='*** expense ***';
Series2.DataSource:=Query1;
end
else if i=2 then
SQL:='*** equity ***';
Series3.DataSource:=Query1;
end
else if i=3 then
SQL:='*** other ***';
Series4.DataSource:=Query1;
SQL:='*** income, expense, equity, other ***';
var Series1: TBarSeries;
Series2: TPointSeries;
Query1: TQuery;
DBChart1.View3D:=False;
Series1:=DBChart1.AddSeries(TBarSeries) as TBarSeries;
Series2:=DBChart1.AddSeries(TPointSeries) as TPointSeries;
Query1:=TQuery.Create(Self);
Query1.DatabaseName:='TeeChart Pro Database';
Query1.SQL.Text:='SELECT LASTNAME, SALARY, BIRTH_DATE From Employee';
Series1.YValues.ValueSource:='SALARY';
Series1.XLabelsSource:='LASTNAME';
Series1.Marks.Style:=smsValue;
Series2.YValues.ValueSource:='BIRTH_DATE';
Series2.XLabelsSource:='LASTNAME';
Series2.YValues.DateTime:=True;
Series2.Marks.Visible:=True;
Series2.Marks.Style:=smsValue;
Series2.OnGetMarkText:=SeriesGetMarkText;
Query1.Active:=True;
procedure TForm1.SeriesGetMarkText(Sender: TChartSeries; ValueIndex: Integer; var MarkText: string);
if (Sender<>nil) and (ValueIndex>-1) then
MarkText:=FormatDateTime('dd/mm/yyyy', Sender.YValue[ValueIndex]);
I want to do what you showed in your first code example. I want to use one Query for each series in a bar chart with 4 bars displaying by month. Each bar represents 1 of 4 values included in the 'Category Type' datafield. But if I am using one Query, how does series1 still hold the correct value if the SQL changes for Series2?
This is what I am doing now and getting ready to add 2 more series for a comparison to last year. So I want to end up with Income/Expenses bars for this year and 2 bars representing last year for comparison.
Here is my code for the 2 chart method:
Creating 3 more Queries is no problem, but I want to figure out how I could simplify it. Both Series are the same including database settings (attached.
for i := 1 to 2 do
Begin
if i = 1 then TopQuery := BarQuery else TopQuery := BarQuery2;
TopQuery.Active := false;
TopQuery.SQL.Clear;
//TopQuery.SQL.Add('SELECT *, ABS(SUM (AMOUNT)) AS ABSTOTAL,');
TopQuery.SQL.Add('SELECT *, ');
TopQuery.SQL.Add(' SUM (AMOUNT) AS TOTAL,');
TopQuery.SQL.Add(' (cast(strftime(''%Y%m'', date) as integer)) AS YEAR_MONTH,');
TopQuery.SQL.Add(' date(DATE,''start of month'') AS MONTH_START,');
TopQuery.SQL.Add(' case strftime(''%m'', DATE) when ''01'' then ''Jan'' when ''02'' then ''Feb'' when ''03'' then ''Mar'' when ''04''');
TopQuery.SQL.Add(' then ''Apr'' when ''05'' then ''May'' when ''06'' then ''Jun'' when ''07'' then ''Jul'' when ''08'' then ''Aug'' when ''09''');
TopQuery.SQL.Add(' then ''Sep'' when ''10'' then ''Oct'' when ''11'' then ''Nov'' when ''12'' then ''Dec'' else '''' end');
TopQuery.SQL.Add(' || " ''" || substr(strftime(''%Y'', date),3) as MON_YEAR,');
TopQuery.SQL.Add('strftime(''%d'', date) AS DAY,');
TopQuery.SQL.Add('(cast(strftime(''%d'', date) as integer)) / 7 + 1 AS WEEK,');
TopQuery.SQL.Add('strftime(''%m'', date) AS MONTH,');
TopQuery.SQL.Add('(cast(strftime(''%m'', date) as integer) + 2) / 3 as QTR');
TopQuery.SQL.Add('FROM TRANSACTIONS');
TopQuery.SQL.Add('INNER JOIN CATEGORIES');
TopQuery.SQL.Add('ON TRANSACTIONS.TREE_NAME=CATEGORIES.CatName');
TopQuery.SQL.Add(Where);
if I = 1 then
if Where = '' then TopQuery.SQL.Add('Where CATEGORIES.Cat_Type = ''Income Categories''') else
TopQuery.SQL.Add('AND CATEGORIES.Cat_Type = ''Income Categories''');
end else
if Where = '' then TopQuery.SQL.Add('Where CATEGORIES.Cat_Type = ''Expense Categories''') else
TopQuery.SQL.Add('AND CATEGORIES.Cat_Type = ''Expense Categories''');
TopQuery.SQL.Add('AND Date BETWEEN "' + FormatDateTime('yyyy-mm-dd',IncExpStart) + '" AND "' + FormatDateTime('yyyy-mm-dd',IncExpEnd) + '"');
//TopQuery.SQL.Add('CATEGORIES.CAT_TYPE, YEAR_MONTH');
TopQuery.SQL.Add('GROUP BY MON_YEAR');
TopQuery.SQL.Add('ORDER BY YEAR_MONTH ASC, CATEGORIES.ROW_ID;');
try
DBChart2.SubTitle.Text.Clear;
DBChart2.SubTitle.Text.Add(DateToStr(IncExpStart) + ' to ' +DateToStr(IncExpEnd));
TopQuery.Active := true;
except
if i = 1 then Series2.Active := false else Series3.Active := false;
If DebugLog.Visible then DebugLog.Lines.Add(TopQuery.Name + ' ERROR: '+ TopQuery.SQL.Text);
if (Series2.Active = false) and (Series3.Active = false) then ChartType.ItemIndex := 1;
//ShowMessage(TopQuery.Name + '=' + TopQuery.SQL.Text);
- 2017-05-03_1152.png (18.7 KiB) Viewed 16198 times
I believe this is more a SQL doubt than a TChart issue.
The goal would be to create a single SQL query merging those two different queries, generating different columns to link to the series.
