Installation of Tee chart 7.12 in Rad 2007
psr
Post by psr » Thu Mar 20, 2008 4:29 pm
I am getting invalid filename exception when installing in RAD 2007 delphi studio. I am using your delphi 2007 update version 7.12.
Raju
Post by Narcís » Thu Mar 20, 2008 4:32 pm
Hi Raju,
Have you tried using TeeInstall.exe included with the v7.12 binary installer? If the problem persists try downloading the installer again as it may have been corrupted.
If this doesn't help don't hesitate to let us know.
psr
Install problem
Post by psr » Thu Mar 20, 2008 5:49 pm
I tried again. I am getting the following msg.
TeeChart Installation
VERSION: 7
RAD 2007.Win32 v11 (BDS v5 Architect)
VERSION: 7
RAD 2007.NET v11 (BDS v5 Architect)
EXCEPTION:
File not found
Post by Narcís » Tue Mar 25, 2008 9:06 am
Hi Raju,
Does the message specify the missing file name?
MagF
Post by MagF » Fri Aug 22, 2008 12:02 pm
I have the same problem.
Using TeeChartPro 7.12 on Delphi2007 (on Vista x64)
I get the following information:
VERSION: 7
RAD 2007.Win32 v11 (BDS v5 Enterprise) (C++)
EXCEPTION:
Invalid filename
No information on which file it is missing or anything.
Are there any manual steps I can do to work around this?
Post by Pep » Fri Aug 22, 2008 12:05 pm
most likely the problem is same as one customer let us know here :
http://www.teechart.net/support/viewtopic.php?t=8249
Take a look, he also explains the solution.
MagF
Post by MagF » Fri Aug 22, 2008 12:49 pm
Well, I already have that folder, so it cant be that.
If I try to recompile, the .NET solution works, but not for Win32.
I get the following error for Win32:
Tee711
Cannot recompile Delphi package: Tee711.dpk
CodeGear Delphi for Win32 compiler version 18.5
Copyright (c) 1983,2007 CodeGear
TeeAbout.pas(1) Fatal: F2039 Could not create output file ':\DelphiComponents\TeeChartPro7\Sources\Compiled\Delphi11\Lib\TeeAbout.hpp'
EXCEPTION:
Compilation aborted.
This is from a fresh installation on a new system.
In the the drive is not shown in the filename above, I dont know if that has anything to do with this error. All my components are installed in H:\DelphiComponenets, but the 'H' is not shown in the filename during compilation above.
I am also running this on Vista x64, but UAC is turned off and I am logged in as an administrator.
Post by Narcís » Mon Aug 25, 2008 10:12 am
Hi MagF,
Could you please right-click on the installer and select the "Run as Administrator" option?
