Keith
![Newbie Newbie](./images/ranks/1star.gif)
Post
by Keith » Fri Feb 23, 2007 11:49 am
Support,
I see this has come up before, but I did not see a solution.
I am using SaveTreeToStream & LoadTreeFromStream to copy the contents of one TTree to another, but I am getting an eternal loop in the 'TeeTreeFindGlobalComponent' procedure when calling LoadTreeFromStream.
Here is the sample code:
procedure TForm1.cmdStreamClick(Sender: TObject);
var
msTemp: TStream;
Form2.Show;
Form1.TreeSource.NoOwnerShapes := False;
Form2.TreeDest.NoOwnerShapes := False;
msTemp := TMemoryStream.Create;
try
SaveTreeToStream(TCustomTree(Form1.TreeSource), msTemp);
msTemp.Position := 0;
LoadTreeFromStream(TCustomTree(Form2.TreeDest), msTemp);
finally
FreeAndNil(msTemp);
Form1 contains the source TTree and Form2 contains the destination TTree.
Kind regards,
Keith Blows
Keith
Post
by Keith » Fri Feb 23, 2007 12:50 pm
Found the problem- seems to be bug in that the component's name is saved with the stream, which causes a problem when trying to load it. This text must be removed from the stream. Here is a simple routine to handle it for you:
procedure FixedSaveTreeToStream(ATeeTree: TCustomTree; AStream: TStream);
var
lTemp: TMemoryStream;
lChar: Byte;
lComponentNameLen: Integer;
lComponentNameLen := Length(ATeeTree.Name);
lTemp := TMemoryStream.Create;
try
SaveTreeToStream(ATeeTree, lTemp); // This saves the component's name in the stream, which causes problems when loading...
// We need to delete the name from the resultant stream- it is located at position 11
lTemp.Position := 0;
AStream.CopyFrom(lTemp, 10);
lChar := 0; AStream.Write(lChar, 1);
lTemp.Position := 11 + lComponentNameLen;
AStream.CopyFrom(lTemp, lTemp.Size - lComponentNameLen - 11);
finally
FreeAndNil(lTemp);
var
Form2.Show;
try
FixedSaveTreeToStream(TreeSource, lTemp);
LoadTreeFromStream(TCustomTree(Form2.TreeDest), lTemp);
finally
