TeeChart for .NET v2023 [14 DEC 2023] RELEASE 2023.12.14
Gemma
Post by Gemma » Tue Dec 12, 2023 9:09 am
Greetings!
Steema is pleased to inform you of the availability of new build 2023.12.14 for the TeeChart for .NET.
The new update includes TeeChart .NET Pro and Business edition binary installers.
Customers with active license subscription can download new Nuget package from website:
TeeChart .NET Pro - www.nuget.org/packages/Steema.TeeChart.NET/4.2023.12.14
TeeChart .NET Business - www.nuget.org/packages/Steema.TeeChart. ... 2023.12.12
Version history for TeeChart .NET can be viewed at the product release notes.
Gemma Gibert
sydro_consult
Re: TeeChart for .NET v2023 [14 DEC 2023] RELEASE 2023.12.14
Post by sydro_consult » Tue Dec 19, 2023 10:36 pm
I have several issues with version 2023.12.14 (using a WinForms project targeting .NET Framework 4.8 ):
* A reference to System.Text.Json is required at runtime. I can compile without this reference, though. Shouldn't this dependency be taken care of by the NuGet package?
* The TeeChart Editor causes an exception regarding a missing assembly PdfSharpCore when clicking on certain tabs in the editor (e.g. the "Legend" tab). I tried adding both the latest stable v1.3.62 as well as the version 1.3.57 of PdfSharpCore specified in the exception message via NuGet to the project, but to no avail. The exception keeps occurring. Shouldn't this dependency be taken care of by the TeeChart NuGet package too?
System.IO.FileLoadException: 'Die Datei oder Assembly "PdfSharpCore, Version=1.3.57.0, Culture=neutral, PublicKeyToken=null" oder eine Abhängigkeit davon wurde nicht gefunden. Eine Assembly mit starkem Namen ist erforderlich.
* In the "Series" tab of the Editor (which is one of the tabs that can be displayed without causing an exception), line series are displayed as filled rectangles (see screenshot), instead of with a line symbol as was the case in previous TeeChart versions
* Trying to test the fix for bug 2635 (legend checkboxes replacement), I still get similar issues as with TeeChart 2023.11.17, which I posted about here:
** Setting Legend.CheckBoxes = True in the code is still possible, but has no effect (why not remove the property completely?)
** Setting Legend.FontSeriesColor = True causes a System.NullReferenceException on load
** Sometimes, clicking a legend item will deactivate a different series than the one clicked. This seems to happen in particular when you have more than just a couple of series in the chart (this was also reported by someone else for version 4.2023.11.6
I have attached a very simple test project for reproducing these issues.
TeeChartTest_4.2023.12.14.zip
(13.67 KiB) Downloaded 329 times
sydro_consult
Post by sydro_consult » Tue Dec 19, 2023 10:48 pm
I also found out that in order to use the new feature where deactivated legend items are shown as strike-through or faded, I have to set TChart1.Legend.ActiveStyle to something other than None. Where do you communicate this kind of information about new features to your users? Am I missing some source of information about new releases? Because it is not mentioned in https://www.steema.com/version_info/net/last nor ist it documented in https://www.steema.com/docs/TeeChartNETReference.htm
Post by Marc » Thu Mar 07, 2024 10:10 am
Please note:
Replies to version announcements are not monitored and will be missed by technical staff; We are reviewing and locking announcements where that has not been the case.
We request that all support posts be created as a new thread to the active forum area.
With thanks.
