Hi Team,
I am unable to install TeeChart Pro ActiveX(TeeChart2023_0_3_20_ActiveX3264.exe) on my server machine. Getting below error, Please let me know how to proceed ,License is active and valid
Error while activating license:
12029 A connection with the server could not be established
Online License activation has failed.
Thanks!
Srikanth Ananthoju
License Activation failed during install latest TeeChart 2023
- TeeChartActivationFailed.JPG (21.69 KiB) Viewed 14286 times
Re: License Activation failed during install latest TeeChart 2023
Hello Srikanth Ananthoju,
Maybe the server was temporally down. Could you please give it another try?
I've tried again,still same issue.
Try replying "No" and try the online activation a second time without closing the installer.
If it still fails, try replying "Yes" and follow the instructions. It should give you a code you could use to activate the installation through the activation form.
