Recompilation tool issue
Fails on installation of Lazarus:
TeeChart Pro
Compilation started: 12/14/2022 12:53:22 PM
Lazarus 2.2.4.0
Cannot recompile Lazarus package: TeeChart.pas
Free Pascal Compiler version 3.2.2 [2022/09/24] for x86_64
Copyright (c) 1993-2021 by Florian Klaempfl and others
Target OS: Win64 for x64
Compiling C:\Delphi\TeeChart Pro VCL FMX Source Code\Source\TeeChart.pas
TeeChart.pas(85,40) Error: Duplicate identifier "TEEACTIVITYGAUGE"
TeeChart.pas(85,62) Error: Duplicate identifier "TEEACTIVITYGAUGEEDIT"
Compiling ArrowCha.pas
Compiling TeEngine.pas
Compiling TeeProcs.pas
Compiling TeCanvas.pas
TeCanvas.pas(790,18) Warning: An inherited method is hidden by "SetJoinStyle(const TPenJoinStyle);"
TeCanvas.pas(3164,1) Fatal: There were 2 errors compiling module, stopping
Fatal: Compilation aborted
Error: C:\lazarus\fpc\3.2.2\bin\x86_64-win64\ppcx64.exe returned an error exitcode
EXCEPTION:
Compilation aborted.
dwpss
TeeChart Pro
Lazarus 2.2.4.0
EXCEPTION:
dwpss
Re: Recompilation tool issue
Yes, I found and fixed those errors yesterday.
I've just sent you the modified units at the mail you have registered in this forum.
Please let us know if there's any other problem with it.
Got past those errors, but it seems there is some pathing needed still...I have sent you the log output file since it is very long.
dwpss
dwpss
The log ends with:
In the meanwhile, I could open the teechart.lpk package and compile and install it from the IDE.
Could you please give it a try?
Sorry for the inconvenience generated.
The log ends with:
I also saw that error and didn't find how to fix it yet.Compiling C:\lazarus\components\ideintf\idewindowintf.pas
idewindowintf.pas(26,3) Fatal: Can't find unit IDEOptionsIntf used by IDEWindowIntf
I can install it manually in the IDE but upon use I get this error when trying to use the TeeChart Editing dialog box...
dwpssRe: Recompilation tool issue
I see the error in "Tree mode". We'll investigate what's wrong.
Meanwhile, please open the "options" and uncheck it.
When doing so I can get a little further but upon choosing an item from the gallery it stops with...
dwpss
dwpss
At TeeGally.pas, find the
For this:
And rebuild the package.
I'm sorry for the inconveniences.
TTeeGallery.SwitchAlternate
procedure and modify this line:Code: Select all
ChartListBox1.Sorted:=True;
{$IFNDEF LCL}
{$ENDIF}
Hello again,
The above could be considered as a fast workaround.
I've just implemented the definitive fix (I hope so) for #2578.
The fix consists on adding a couple of lines of code at
TTeeGallery.CreateChartList
, in TeeGally.pas unit, setting Sorted:=False
befode updating the ChartListBox1
and restoring it at the end:
Procedure TTeeGallery.CreateChartList(Const APage:String);
ChartListBox1.Items.BeginUpdate;
ChartListBox1.Sorted:=False;
try
finally
ChartListBox1.Sorted:=AlternateStyle;
ChartListBox1.Items.EndUpdate;
That got rid of the sort error, but things are odd.
If you choose something from the series gallery the associated code is not generated and if you do too much in the gallery it crashes.
Here are some screenshots... The resultant code: After making changes to a series from the gallery, like checking "smooth" etc.:
pssdw
pssdw
Also, I have tried to use without the Gallery with this test...
pssdw
pssdw
uses
Classes, SysUtils, Forms, Controls, ExtCtrls, Graphics, Dialogs, StdCtrls,
TeEngine, Chart, TeeGDIPlus, Series, TeeProcs;
type
{ TForm1 }
TForm1 = class(TForm)
Chart1: TChart;
Series1: TLineSeries;
procedure FormShow(Sender: TObject);
private
public
var
Form1: TForm1;
implementation
{$R *.lfm}
{ TForm1 }
procedure TForm1.FormShow(Sender: TObject);
Series1.FillSampleValues(50);
- Screenshot 2023-01-02 155516.png (8.42 KiB) Viewed 6042 times
