Hi Steema,
When I zoom into a chart I'd like to get the zoomed MinX , MinY, MaxX, and MaxY values and thought it would be in the Zoomed event but am finding it challenging to figure this out. Please see attached screenshots. I'm doing something wrong.
Thanks as always!
Joseph
Read Zoomed Values
Read Zoomed Values
- results.jpg (31.28 KiB) Viewed 4998 times
- Code.jpg (82.22 KiB) Viewed 4998 times
Re: Read Zoomed Values
using the following code works fine. Could you please check?
Steema.TeeChart.TChart _chart = new Steema.TeeChart.TChart();
Controls.Add(_chart);
var line = new Steema.TeeChart.Styles.Line(_chart.Chart);
line.XValues.DateTime = true;
line.FillSampleValues();
_chart.Axes.Bottom.Labels.Angle = 90;
_chart.Zoomed += _chart_Zoomed;
private void _chart_Zoomed(object? sender, EventArgs e)
MessageBox.Show("Min YVal:" + _chart.Axes.Left.Minimum.ToString() +
" | Max YVal:" + _chart.Axes.Left.Maximum.ToString());
MessageBox.Show("Min XVal:" + DateTime.FromOADate(_chart.Axes.Bottom.Minimum).ToString() +
" | Max XVal:" + DateTime.FromOADate(_chart.Axes.Bottom.Maximum).ToString());
Pep Jorge
http://support.steema.com
Thanks, I will try this.
