Steema version = Steema.TeeChart.NET.Xamarin.Forms v4.2021.4.22
Xamarin Forms version = v5.0.0.2012
Development platform = Visual Studio 2019 Pro v16.9.1
Target device = Android 6.0 (API 23) to API 10.0 (API 29) smallest res = 480x800
I am trying to write code to re-size aspects of a circular gauge control when the gauge itself is resized. My code does work, but only when the gauge control is pressed after being resized. I assume I am not calling my resize code in the correct event (currently calling in the AfterDraw event) but I cannot determine the best solution.
I have written a small test solution (attached) to demonstrate what I am trying to achieve.
In my test App whenever the SIZE button(s) are pressed, the gauge control does resize but the label font, line band & center point only size correctly when the gauge control is subsequently pressed.
Incorrect result
Correct result (after gauge control pressed)
All feedback & assistance greatly appreciated
Scale gauge chartview elements on resize (Xamarin Forms)
- GaugeResizeTestApp.zip
- (353.1 KiB) Downloaded 659 times
Re: Scale gauge chartview elements on resize (Xamarin Forms)
ok, let me take a look and check your project and back to you with a possible solution as soon as possible.
Pep Jorge
http://support.steema.com
Hello Scobie,
in order to fix this problem just add an InternalDraw at the end of the resize method :
// ### AXIS ###
CircularGauge.Axis.Labels.Font.Size = 7.0D * (CircularGauge.XRadius / 100D);
this.Chart.Chart.InternalDraw();
Pep Jorge
Thank you for your help.
I have added the Chart.Chart.InternalDraw() method call to the end of the Resize method & while it does re-draw the font, centre point & colour band in the correct size it leaves the original (incorrectly sized) chart elements in position, creating a "shadow" effect - see image.
Should I be calling some sort of repaint or invalidate method before the InternalDraw method to remove the old graphics?
yes, you're correct, it seems to be a repaint problem. I'll add as a bug on our bug list in order to be addressed.
In meantime I found a solution, it's to use the OnBeforeDraw event to hide the axis labels and then make them visible again once these have been resized :
// Add the beforeDraw method at the CreateGauge method
cv.Chart.BeforeDraw += Chart_BeforeDraw;
private void Chart_BeforeDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
CircularGauge.Axis.Labels.Visible = false;
// Add these lines at the end of the Resize method
CircularGauge.Axis.Labels.Visible = true;
Pep Jorge
Hello
I have implemented your suggestion, along with further lines to deal with the center, hand & green/red lines & the solution is working...
Thankyou for your help to get this code working.
CircularGauge.Center.Visible = false;
CircularGauge.Hand.Visible = false;
CircularGauge.GreenLine.Visible = false;
CircularGauge.RedLine.Visible = false;
CircularGauge.Center.Visible = true;
CircularGauge.Hand.Visible = true;
CircularGauge.GreenLine.Visible = true;
CircularGauge.RedLine.Visible = true;
