Elite
![Newbie Newbie](./images/ranks/1star.gif)
Post
by Elite » Wed Jun 17, 2020 8:59 am
I created a 3D chart using IsoSurface. It can run smoothly when 1000 points are loaded, but when I append to 3 million points, the rotating chart is not smooth. How should I optimize it.
The code is as follows
IsoSurface isoSurface1 = new IsoSurface(tChart1.Chart);
isoSurface1.BandPen.Visible = false;
isoSurface1.IrregularGrid = true;
foreach (double time in dataMap.Keys)
double[] values = dataMap[time];
for (int z = startWavelength; z <= endWavelength; z++)
int index = z - startWavelength;
isoSurface1.Add(time, values[index], z);
- Guru
Post
by Christopher » Wed Jun 17, 2020 4:44 pm
Elite wrote: ↑Wed Jun 17, 2020 8:59 am
Here I'm using this code:
_tChart.Aspect.View3D = true;
_tChart.Aspect.Orthogonal = false;
_tChart.Aspect.Zoom = 80;
_tChart.Aspect.Chart3DPercent = 80;
_tChart.Legend.Visible = false;
var surface = new IsoSurface(_tChart.Chart);
surface.BandPen.Visible = false;
surface.FillSampleValues(20);
_tChart.Tools.Add(typeof(Rotate));
Note the removal of the BandPen, which may make a difference for you.
In general I would not expect GDI+ to be able to handle efficiently the rendering of so many objects; the kind of performance you're looking for is more likely to be found in systems with retained mode graphics rather than immediate mode graphics such as DirectX, OpenGL etc.
Elite
Post
by Elite » Mon Sep 14, 2020 2:48 am
Hello, can TeeChart support retained mode? Do you have a better solution?
- Guru
Post
by Christopher » Mon Sep 14, 2020 7:27 am
Elite wrote: ↑Mon Sep 14, 2020 2:48 am
Unfortunately we don't have a high-performance retained-mode graphics version of TeeChart at the moment, I'm afraid, and I don't believe we have plans to make one available in the near future.
