After version updating TeeChart 4.1.2012.1032 ==> 4.2018.11.27
The top outer border does not appear.
Can you guess what the problem is?
TO
- Guru
Re: The top outer border does not appear.
Do you have the Back Wall set to visible? Using the following code works as expected here:
InitializeChart();
tChart1.Walls.Back.Visible = true;
tChart1.Walls.Back.Pen.Color = Color.Red;
Hello.
I tried following the attached code above , but it doesn't work.
There is no change..
Do you have any other ideas?
![Neutral :|](./images/smilies/icon_neutral.gif)
- Guru
please find attached a Visual Studio project which correctly replicates the code I gave you in my last post:
Can you please modify the code in this project and post it back here so I can reproduce your problem on my machine?
It helped solve the problem. Thank you
![Very Happy :D](./images/smilies/icon_biggrin.gif)
