In a chart I am creating I have labels that are put with some descriptive text at the bottom of a chart:
The problem is when I make the chart just a little narrower, even though there is plenty of room, a label gets dropped (notice the label under the 4th bar).
Is there any way to modify the margin each label requires? I need to have the labels display.
Ed Dressel
Labels at bottom of chart are dropped
Re: Labels at bottom of chart are dropped
Hello Ed,
I've tried to reproduce the problem with the following code and TeeChart v2017.21 but it seems to work fine for me here:
uses Series;
const
initialBenefit : array[0..3] of double = (5336,6226,7204,8271);
Chart1.Align:=alClient;
Chart1.View3D:=False;
Chart1.Legend.Visible:=False;
Chart1.Walls.Visible:=False;
Chart1.Color:=clWhite;
Chart1.Title.Visible:=False;
Chart1.MarginTop:=5;
Chart1.MarginLeft:=5;
Chart1.Axes.Left.Increment:=1000;
Chart1.Axes.Left.Ticks.Visible:=False;
Chart1.Axes.Left.MinorTicks.Visible:=False;
Chart1.Axes.Left.Grid.Style:=psDot;
Chart1.Axes.Left.Title.Text:='Additional Monthly Savings'+sLineBreak+'Needed to Account for Shortfall';
Chart1.Axes.Left.Title.Font.Color:=clBlue;
Chart1.Axes.Left.Title.Font.Style:=[fsBold];
Chart1.Axes.Bottom.Ticks.Visible:=False;
Chart1.Axes.Bottom.MinorTicks.Visible:=False;
Chart1.Axes.Bottom.Grid.Visible:=False;
with Chart1.AddSeries(TBarSeries) as TBarSeries do
Color:=RGB(83,138,175);
Pen.Visible:=False;
Marks.Color:=RGB(211,228,236);
AddBar(3878, 'Age 64', clTeeColor);
AddBar(3880, 'Age 66', clTeeColor);
AddBar(3913, 'Age 68', clTeeColor);
AddBar(3978, 'Age 70', clTeeColor);
OnGetMarkText:=SeriesGetMarkText;
Self.Width:=530;
Self.Height:=350;
procedure TForm1.SeriesGetMarkText(Sender: TChartSeries; ValueIndex: Integer; var MarkText: String);
if Assigned(Sender) and (ValueIndex>-1) and (ValueIndex<Sender.Count) then
MarkText:=MarkText+sLineBreak+FormatFloat('$#,##0.##',Sender.YValue[ValueIndex]);
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
if (Sender=Chart1.Axes.Bottom) and (ValueIndex>-1) and (ValueIndex<SizeOf(initialBenefit)) then
LabelText:='Initial Benefit:'+sLineBreak+FormatFloat('$#,##0.##',initialBenefit[ValueIndex]);
- labels_overlap.png (11.99 KiB) Viewed 5981 times
