XE2, TeeChart Pro 2014.11 04.09
In the attached demo, the series caption and legend overlap. If it is vertically enlarged, the problem does not occur--but I don't want to waist vertical spacing.
Is there a way that fixes this that doesn't waist vertical spacing?
Ed Dressel
Series Caption and Legend Overlap
- Advanced
- Legend and Caption Overwrite.rar
- (1.84 KiB) Downloaded 968 times
Re: Series Caption and Legend Overlap
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=947
In the meanwhile, you could use a TAnnotationTool instead of using the bottom axis title, and recalculate the margin on the bottom manually. Ie:
uses Series, Math, TeeTools;
var bottomTitle: TAnnotationTool;
var i: Integer;
Chart1.Align:=alClient;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
with Chart1.AddSeries(TBarSeries) as TBarSeries do
FillSampleValues();
Marks.Visible:=false;
for i:=0 to Count-1 do
Labels[i]:=FormatFloat('#0.##', YValue[i]) + #13 + 'Extra Line 1' + #13 + 'Extra Line 2';
Chart1.Axes.Bottom.Title.Text:='Bottom Axis Title';
recalcBottomMargin;
procedure TForm1.Chart1Resize(Sender: TObject);
recalcBottomMargin;
procedure TForm1.recalcBottomMargin;
function CountOccurences( const SubText: string;
const Text: string): Integer;
Result := Pos(SubText, Text);
if Result > 0 then
Result := (Length(Text) - Length(StringReplace(Text, SubText, '', [rfReplaceAll]))) div Length(subtext);
var i, maxHeight, nLines, tmpMargin: Integer;
Chart1.Draw;
maxHeight:=0;
for i:=0 to Chart1[0].Count-1 do
nLines:=CountOccurences(#13, Chart1[0].Labels[i]) + 1;
maxHeight:=Max(maxHeight, nLines*Chart1.Canvas.TextHeight(Chart1[0].Labels[i]));
tmpMargin:=maxHeight;
if Chart1.Axes.Bottom.Title.Visible or Assigned(bottomTitle) then
if not Assigned(bottomTitle) then
bottomTitle:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
with bottomTitle do
Text:=Chart1.Axes.Bottom.Title.Text;
Shape.Assign(Chart1.Axes.Bottom.Title);
Left:=Chart1.Axes.Bottom.IStartPos+(Chart1.Axes.Bottom.IAxisSize div 2) - (Chart1.Canvas.TextWidth(Text) div 2);
tmpMargin:=Chart1.Axes.Bottom.TickLength+maxHeight+Chart1.Canvas.TextHeight(Text);
Top:=Chart1.Axes.Bottom.PosAxis+tmpMargin;
Chart1.MarginBottom:=tmpMargin;
Chart1.Axes.Bottom.Title.Visible:=false;
Chart1.MarginUnits:=muPixels;
- Advanced
Thank you for your response.
I merged your code with my demo and the problem still occurs--the problem for me was legend overlap with captions. See the attached demo.
Is there a work around?
Ed Dressel
Ed Dressel
- (2.36 KiB) Downloaded 997 times
Hi Ed,
You can do something similar than what I was doing, setting the legend to be in the bottom though a custom position and adding the necessary margin to the bottom:
constructor TForm1.Create(aOwner: TComponent);
var
I: Integer;
lValue: Double;
lCaption: string;
inherited;
FAnnTool := nil;
lValue := 100;
for I := 1 to 5 do
lValue := lValue * (1 + (Random * 0.2));
lCaption := inttostr(I);
if I = 3 then
lCaption := lCaption + #13 + 'Extra Caption Line';
Series1.AddBar(lValue, lCaption, clTeeColor);
chrtSavingsNeeded.Axes.Bottom.Title.Text:='Bottom Axis Title';
RecalcBottomMargin;
procedure TForm1.RecalcBottomMargin;
function CountOccurences( const aSubText, aText: string): Integer;
Result := Pos(aSubText, aText);
if Result > 0 then
Result := (Length(aText) - Length(StringReplace(aText, aSubText, '', [rfReplaceAll]))) div Length(aSubtext);
var i, maxHeight, nLines, tmpMargin, tmpHeight: Integer;
chrtSavingsNeeded.Draw;
chrtSavingsNeeded.Canvas.Font.Assign(chrtSavingsNeeded.Axes.Bottom.Title.Font);
maxHeight:=0;
for i:=0 to chrtSavingsNeeded[0].Count-1 do
nLines:=CountOccurences(#13, chrtSavingsNeeded[0].Labels[i]) + 1;
maxHeight:= Max(maxHeight, nLines*chrtSavingsNeeded.Canvas.TextHeight(chrtSavingsNeeded[0].Labels[i]));
tmpMargin:=maxHeight+chrtSavingsNeeded.Axes.Bottom.TickLength;
if chrtSavingsNeeded.Axes.Bottom.Title.Visible or Assigned(FAnnTool) then
if not Assigned(FAnnTool) then
FAnnTool:=chrtSavingsNeeded.Tools.Add(TAnnotationTool) as TAnnotationTool;
with FAnnTool do
Text := chrtSavingsNeeded.Axes.Bottom.Title.Text;
Shape.Assign(chrtSavingsNeeded.Axes.Bottom.Title);
Left := chrtSavingsNeeded.Axes.Bottom.IStartPos+(chrtSavingsNeeded.Axes.Bottom.IAxisSize div 2) - (chrtSavingsNeeded.Canvas.TextWidth(Text) div 2);
Top := chrtSavingsNeeded.Axes.Bottom.PosAxis+tmpMargin;
tmpMargin := tmpMargin+chrtSavingsNeeded.Canvas.TextHeight(Text);
chrtSavingsNeeded.Axes.Bottom.Title.Visible:=false;
if chrtSavingsNeeded.Legend.Visible and (chrtSavingsNeeded.Legend.Alignment = laBottom) then
chrtSavingsNeeded.Legend.CustomPosition:=true;
chrtSavingsNeeded.Legend.Left:=(chrtSavingsNeeded.Width div 2) - (chrtSavingsNeeded.Legend.Width div 2);
tmpHeight:=chrtSavingsNeeded.Legend.Height;
chrtSavingsNeeded.Legend.Top:=chrtSavingsNeeded.Axes.Bottom.PosAxis+tmpMargin;
tmpMargin:=tmpMargin+tmpHeight;
chrtSavingsNeeded.MarginUnits:=muPixels;
chrtSavingsNeeded.MarginBottom:=tmpMargin;
procedure TForm1.Resize;
inherited;
RecalcBottomMargin;
- Advanced
Thank you for your responses.
If I use the Footer.Text property for my charts sub-title, the overlap still occurs. (I tried to change the code you wrote but could not get it to work with my new demo).
Ed Dressel
Ed Dressel
- (2.63 KiB) Downloaded 981 times
- Site Admin
- Contact:
Hi Ed,
With the modifications David Berneda made to the code it's working fine now:
So you may expect this being fixed in the next maintenance release. If you are interested, you can also check David's new beta version here.
- Advanced
It's difficult to release beta code to my end users--it doesn't go over very well when it doesn't work. How close is this to being a final release?
- Site Admin
- Contact:
Hello Ed,
We expect this version being out in about one month.TestAlways wrote:How close is this to being a final release?
