1. I want to know how to add "null" value to a Bar.
Please refer to the attchment, which is waht i want.
There is an empty value among a value list.e.g.,[2,4,3, ,44,55]
How can i create a bar based on this value list?
In TeeChart, I try the following code, but it fails..
Bar series = new bar(tChart2.getChart());
series.add(2);
series.add(4);
series.add(3);
series.add(null); //this is impossible
series.add(44);
series.add(55);
2. by the teechart example,
I know that i can use the following code to do this:
series.setNull(3);//index 3
Are there any other method to do this task?
What's more, in the example: "Chart Styles/ Standard /Line(Strip)/ Line/Horizontal line TreatNulls"
When i choose "Don't paint", the 12th is not painted, but the 13th still is painted.
I think both of them should not be painted.
Null value bug
Null value bug
- 1.jpg (37.91 KiB) Viewed 14757 times
Re: Null value bug
I want to add null to a bar.
The TeeChart example is about line.
So i use bar.addNull().
there are several null values, so i use
bar.add(3); bar.addNull(). bar.add(4), then bar.addNull()
IndexoutofBoundsExpection Error happens.
Re: Null value bug
Because the above approach fails.
So i search this forum to find more useful information.
I find http://www.teechart.net/support/viewtop ... ull#p56858
which contain the following code:
I try the code, but my result is different , all the bars are painted even setNull().
I am using the latest version.
Could you please try it in the latest version..
for (int i=0; i<3; i++) {
Bar b = new Bar(tChart1.getChart());
b.fillSampleValues();
b.setNull(2);
if (i>0) b.setNull(3);
if (i>1) b.setNull(4);
Re: Null value bug
It's a known bug already int he wish list to be fixed for future releases (TJ71016752). We'll try to fix it for the upcoming releases.
I'm afraid I can't think on a workaround at the moment.
Re: Null value bug
Hello, I try the new version TeeChart Java v3.2013.1219 version.
I find a problem, it as follows.
if i use bar.add(-10), it will result that Null will be showed. (Null-2.png)
however, if i use bar.add(10), it will result that Null will not be showed. (Null-1.png)
I think in both cases the null should not be showed.
tChart = new TChart();
Series bar = new Bar(tChart.getChart());
bar.add(-10); //null showed
//bar.add(10); //null not showed.
bar.addNull();
bar.add(5);
bar.add(6);
- Null-1.png (13.02 KiB) Viewed 14468 times
- Null-2.png (13.32 KiB) Viewed 14474 times
Re: Null value bug
http://bugs.teechart.net/show_bug.cgi?id=565
Feel free to add your mail to the CC so you'll receive an notice when the status of the ticket will change.
If I scroll down the chart, I also see the null value drawn when bar.add(10) is being used. It's just that it's so thin that it's not visible with the default axis scale.rubby wrote:if i use bar.add(-10), it will result that Null will be showed. (Null-2.png)
I've added it to the bug tracker:rubby wrote:I think in both cases the null should not be showed.
