My right-aligned legend is always 0 pixels from the right side of my chart. I would like to add a couple of pixels spacing, but can't figure out how. Looking through the source code, it seems no such feature is available.
Any ideas?
Right-aligned legend has no margin
Re: Right-aligned legend has no margin
You can add some Horizontal Margin between the legend and the Chart with:
Note if your Legend is TOP/BOTTOM aligned, you'll have to use setVertMargin instead:
tChart1.getLegend().setHorizMargin(10);
tChart1.getLegend().setAlignment(LegendAlignment.BOTTOM);
tChart1.getLegend().setVertMargin(10);
Thanks. I tried that, but it doesn't work. However, I found a workaround:
_chart.setLegendResolver(new LegendAdapter() {
@Override
public Rectangle getBounds(Legend legend, Rectangle rectangle) {
return new Rectangle(rectangle.x, rectangle.y, rectangle.width - 6, rectangle.height);
Though, I would still consider this a bug. setHorizMargin has no effect (Android 4.2.2).
@Override
It does work for me with the latest TeeChart Java for Android, v3.2012.1120:
Android emulator, v4.2.2
tChart1.getHeader().setVisible(false);
Line line1 = new Line(tChart1.getChart());
line1.fillSampleValues();
tChart1.getLegend().setHorizMargin(100);
That looks like 100 pixels on the left. What about the right side? In my app it touches the border of the entire TChart view.
You can also set some Right Margin like follows:
If you still find any problem with it, please arrange a simple example project we can run as-is to reproduce the problem here.
tChart1.getPanel().setMarginUnits(PanelMarginUnits.PIXELS);
tChart1.getPanel().setMarginRight(20);
setMarginRight did the trick! Thanks!
