Labels overwrite on axis
TestAlways
Post by TestAlways » Fri Oct 12, 2012 11:44 pm
XE2, TChart 2012.06.120613
I am updating my help file with some new images and see that in the old image, the X axis labels did not overwrite, but in version I am using, there is a problem with X axis labels:
Is this a known issue? Any fix for it?
Re: Labels overwrite on axis
Post by Narcís » Mon Oct 15, 2012 9:34 am
Hi TestAlways,
Which version number is the old version? Could you please attach a simple example project we can run "as-is" to reproduce the problem here and try to find a solution to it?
TestAlways
Post by TestAlways » Mon Oct 15, 2012 2:57 pm
I don't know the version it worked right.
Demo attached.
Ed Dressel
Label Overlap.zip
(6.15 KiB) Downloaded 1821 times
Post by Narcís » Tue Oct 16, 2012 9:03 am
Hi Ed,
Thanks for the example project. This was probably due to some changes to allow text labels from all series in a chart. Prior to that only text labels from the first series were plotted. You can solve the issue populating your series in a slightly different way and use series values as labels:
  lIdx := 2000;
  for lYear in FYears do
    inc(lIdx);
    lsrsClientValue.AddXY(lIdx, lYear.Value1, IntToStr(lIdx));
    if lYear.Value2 > 0 then
      lsrsSpouseValue.AddXY(lIdx, lYear.Value2, IntToStr(lIdx))
      lsrsSpouseValue.AddNullXY(lIdx, 0);
    if lYear.Value3 > 0 then
      lsrsBenesValue.AddXY(lIdx, lYear.Value3, IntToStr(lIdx))
      lsrsBenesValue.AddNullXY(lIdx, 0);
    if lYear.Value4 > 0 then
      lsrsGrandBenes.AddXY(lIdx, lYear.Value4, IntToStr(lIdx))
      lsrsGrandBenes.AddNullXY(lIdx, 0);
  chrActValues.Axes.Bottom.LabelStyle:=talValue;
Alternatively, you could keep using AddNull() and manually set bottom axis range. Find attached the project with the modifications.
Label Overlap.zip
(76.26 KiB) Downloaded 1775 times
