Flickering on IOS
jls
Flickering on IOS
Post by jls » Mon Oct 08, 2012 1:56 pm
Then you select a series on IOS the chart is flickering.
Is it possible to avoid this?
Jørgen
Re: Flickering on IOS
Post by Yeray » Tue Oct 09, 2012 1:27 pm
Hi Jørgen,
Are you reproducing this in any of the examples of the demo?
Maybe in the testing example I posted here?
jls
Post by jls » Tue Oct 09, 2012 1:58 pm
This sample flickers:
http://www.steema.com/files/public/teec ... g/test.htm
not always, try to click on the series in the legend.
Jørgen
Post by Narcís » Wed Oct 17, 2012 8:02 am
Hi Jørgen,
Some enhancements have been done to TeeChart.js and we are not able to reproduce this issue here now. I'll send you the current version, can you please check if it solves the problem for you?
jls
Post by jls » Wed Oct 17, 2012 9:25 am
Now it doesn't flicker but it is not possible to select series with single tap
if you swipe over the series it is selected
Added sample chart
rr.zip
(255.8 KiB) Downloaded 1216 times
jls
Post by jls » Fri Oct 26, 2012 12:37 pm
Any updates?
Post by Pep » Wed Oct 31, 2012 3:56 pm
Hi Jørgen,
this should be related with the focused html5 canvas element. In focus is not assigned, user have to tap over the object before to be able to swipe of tap over the chart Series.
The following code shows how to set a focus for specific elements :
   <canvas id="camvas"
           width="500px"
           height="500px"
           tabindex="1">
   </canvas>
jls
Post by jls » Thu Nov 01, 2012 11:39 am
Changed this
<BODY onload="draw()" onresize="resize()">
<br><canvas id="canvas" style="height:90%; width: 100%; align: center;" tabindex="1";>
</canvas>
</BODY>
but that did not help.
Must I do something else to make it work?
rr.zip
(1.58 KiB) Downloaded 1167 times
jls
Post by jls » Fri Nov 16, 2012 12:07 pm
Any idea then you will release a version that woks better on IOS?
Post by Pep » Mon Nov 19, 2012 5:08 pm
Hi
we're working on this version in order to improve its functionality, I've noticed that using zoom from a device does not work at all, due to the touch gestures, however, I can do a scroll at in this example (which I'm not sure if this is what you're trying to accomplish or just do a tap over the series pointer). Could you please check if it's working for you ?
You can also try to run this example which uses tap, but for the moment the tap it's not very accurate for use into the device.
jls
Post by jls » Tue Nov 20, 2012 2:30 pm
Scroll sample is ok.
This doesn't work:
http://www.steema.com/files/public/teec ... aphics.htm
It is not possible to select a series.
This work if you move you finger to the pie instead of taping it.
http://www.steema.com/files/public/teec ... ltipie.htm
Jørgen
Post by Pep » Thu Nov 22, 2012 2:29 pm
Hi Jørgen,
ok, we're working on these issues, gestures on devices.
We hope to have a new maintenance release available shortly.
