tchart import : Wrong *.tee file format
sunxp
Post by sunxp » Fri Jan 12, 2018 9:22 am
I want to export tchart config and then import config stream :
	CExport export1 = (CExport)m_tchart.get_Export();
	VARIANT var = export1.SaveToXMLStream(TRUE, TRUE);
	CImport import1 = (CImport)m_tchart.get_Import();
	import1.LoadFromStream(var);
it shows error message: "Wrong *.tee file format"
can you show where the problem is?
or would tell me how to do?
TChart version: 2017 ActiveX
Re: tchart import : Wrong *.tee file format
Post by Yeray » Fri Jan 12, 2018 3:34 pm
You are saving using XML and importing using Native tee format. Try using AsNative.SaveToStream to export your chart. Ie this works fine for me in VB6:
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scPie
  TChart1.Series(0).FillSampleValues 5
  TChart2.Import.LoadFromStream TChart1.Export.asNative.SaveToStream(True)
sunxp
Post by sunxp » Mon Jan 15, 2018 2:36 am
Thanks for your answer. I have another question:
I saved the TChart(looks like attached file : origin.png) as *.tee file,
but when i open the saved file(*.tee file), it becomes this: saved.png, the background is changed.
can you help me to fix it?
Post by Yeray » Mon Jan 15, 2018 8:54 am
I've reproduced this problem so I've added it tot he public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1966
Thanks for reporting it.
