Multiply left axes
Multiply left axes
I try to use multiply left axes. an axis for each series.
I look at the demo demos/axes/multiple_axes.htm and change all start end to 0-100
I want to be able to decide what axis will be visible on the left labels.
If I make only one axis visible, only the series for this axis is visible and this is not working for me.
Is there a way I can select the axis that will show the lables on the left and still show all serieses on the chart?
Amos
Amos
Re: Multiply left axes
Hello Amos,
In general, an axis (and the labels on it) is only drawn when it has at least one series with some visible point associated to it.
If I understand you correctly, you want to have a number of vertical axes, but only one of them visible at a time. And all your series always visible.
To do this, you just need to keep all your series assigned to the axis to be shown. Ie:
<!DOCTYPE html>
<html>
<head>
<title>Testing</title>
<!--[if lt IE 9]>
<![endif]-->
<script src="../src/teechart.js" type="text/javascript"></script>
var Chart1;
function draw() {
for (var i=0; i<4; i++) {
Chart1.addSeries(new Tee.Line()).addRandom();
var axis1=Chart1.axes.left;
var axis2=Chart1.axes.add(false,false);
var axis3=Chart1.axes.add(false,false);
var axis4=Chart1.axes.add(false,false);
axis1.format.stroke.fill="red";
axis1.labels.format.font.fill="red";
axis1.title.text="axis1";
axis1.title.format.font.fill="red";
axis2.format.stroke.fill="green";
axis2.labels.format.font.fill="green";
axis2.title.text="axis2";
axis2.title.format.font.fill="green";
Chart1.panel.margins.left=0;
Chart1.draw();
function changeAxis(numAxis) {
var a, m;
if (numAxis=="0") {
a=Chart1.axes.left;
m=0;
else {
a=Chart1.axes.items[parseInt(numAxis)+3];
m=11;
for (var i=0; i<Chart1.series.count(); i++) {
Chart1.series.items[i].vertAxis = a;
Chart1.panel.margins.left=m;
Chart1.draw();
</script>
</head>
<body onload="draw()">
<br>
<div style="float:left">
<select id="axis_num" onchange="changeAxis(value)">
<option value="0">axis1</option>
<option value="1">axis2</option>
<option value="2">axis3</option>
<option value="3">axis4</option>
</select>
</div>
<center>
<canvas id="canvas1" width="600" height="400">
</canvas>
</center>
<br>
</body>
</html>
thanks for you answer.
What I wanted to do is to show on the chart each series using its own left axis, but to display only one axis.
if i have 2 series, one values range are 100-200 and the other values range is 1000-2000, when i show then on same chart they are far from each other, I want to be able to set min,max for each series and show them close together on same chart.
I could do it when adding left axis for each series, but the problem that the labels are for all axes and are over each other.
can I show only labels fro one axes?
Amos
Amos
Hello Amos,
That's easier. You can create an axis for each series and hide the labels, grid, ticks for all the axes, except for one. Ie:
for (var i=0; i<2; i++) {
Chart1.series.items[1].vertAxis=axis2;
axis2.labels.visible=false;
axis2.grid.visible=false;
axis2.ticks.visible=false;
That is working for me.
Why the width of the labels is different if i use other axis.
How can I make the width constant for all left axes that I display?
Amos
Amos
Hi Amos,
Just keep in mind that Axis.adjustRect function was designed to only have one vertical and one horizontal not-custom visible axes.
The labels width isn't considered when adjusting the chartRect for custom axes, at Axis.adjustRect function.samos wrote:Why the width of the labels is different if i use other axis.
You could set your "custom" axes to be custom=false and their labels will also be considered.samos wrote:How can I make the width constant for all left axes that I display?
Thanks for your answer.
is there a way I can make the left axis width fixed. Setting it to specific pixels size.
I need it because I have 3 charts, and i want them to have the same x values (DateTime).
So I need the charts to be exactly the same width, and it is not working like that for different values.
Amos
Amos
