Series Caption and Legend Overlap
TestAlways
Post by TestAlways » Mon Oct 06, 2014 9:05 pm
XE2, TeeChart Pro 2014.11 04.09
In the attached demo, the series caption and legend overlap. If it is vertically enlarged, the problem does not occur--but I don't want to waist vertical spacing.
Is there a way that fixes this that doesn't waist vertical spacing?
Ed Dressel
Legend and Caption Overwrite.rar
(1.84 KiB) Downloaded 968 times
Re: Series Caption and Legend Overlap
Post by Yeray » Tue Oct 07, 2014 9:36 am
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=947
In the meanwhile, you could use a TAnnotationTool instead of using the bottom axis title, and recalculate the margin on the bottom manually. Ie:
uses Series, Math, TeeTools;
var bottomTitle: TAnnotationTool;
var i: Integer;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
    FillSampleValues();
    Marks.Visible:=false;
    for i:=0 to Count-1 do
      Labels[i]:=FormatFloat('#0.##', YValue[i]) + #13 + 'Extra Line 1' + #13 + 'Extra Line 2';
  Chart1.Axes.Bottom.Title.Text:='Bottom Axis Title';
  recalcBottomMargin;
procedure TForm1.Chart1Resize(Sender: TObject);
  recalcBottomMargin;
procedure TForm1.recalcBottomMargin;
  function CountOccurences( const SubText: string;
                            const Text: string): Integer;
    Result := Pos(SubText, Text);
    if Result > 0 then
      Result := (Length(Text) - Length(StringReplace(Text, SubText, '', [rfReplaceAll]))) div  Length(subtext);
var i, maxHeight, nLines, tmpMargin: Integer;
  Chart1.Draw;
  maxHeight:=0;
  for i:=0 to Chart1[0].Count-1 do
    nLines:=CountOccurences(#13, Chart1[0].Labels[i]) + 1;
    maxHeight:=Max(maxHeight, nLines*Chart1.Canvas.TextHeight(Chart1[0].Labels[i]));
  tmpMargin:=maxHeight;
  if Chart1.Axes.Bottom.Title.Visible or Assigned(bottomTitle) then
    if not Assigned(bottomTitle) then
      bottomTitle:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
    with bottomTitle do
      Text:=Chart1.Axes.Bottom.Title.Text;
      Shape.Assign(Chart1.Axes.Bottom.Title);
      Left:=Chart1.Axes.Bottom.IStartPos+(Chart1.Axes.Bottom.IAxisSize div 2) - (Chart1.Canvas.TextWidth(Text) div 2);
      tmpMargin:=Chart1.Axes.Bottom.TickLength+maxHeight+Chart1.Canvas.TextHeight(Text);
      Top:=Chart1.Axes.Bottom.PosAxis+tmpMargin;
      Chart1.MarginBottom:=tmpMargin;
    Chart1.Axes.Bottom.Title.Visible:=false;
  Chart1.MarginUnits:=muPixels;
TestAlways
Post by TestAlways » Tue Oct 07, 2014 2:05 pm
Thank you for your response.
I merged your code with my demo and the problem still occurs--the problem for me was legend overlap with captions. See the attached demo.
Is there a work around?
Ed Dressel
(2.36 KiB) Downloaded 996 times
Post by Yeray » Tue Oct 07, 2014 3:14 pm
Hi Ed,
You can do something similar than what I was doing, setting the legend to be in the bottom though a custom position and adding the necessary margin to the bottom:
constructor TForm1.Create(aOwner: TComponent);
var
  I: Integer;
  lValue: Double;
  lCaption: string;
  inherited;
  FAnnTool := nil;
  lValue := 100;
  for I := 1 to 5 do
    lValue := lValue * (1 + (Random * 0.2));
    lCaption := inttostr(I);
    if I = 3 then
      lCaption := lCaption + #13 + 'Extra Caption Line';
    Series1.AddBar(lValue, lCaption, clTeeColor);
  chrtSavingsNeeded.Axes.Bottom.Title.Text:='Bottom Axis Title';
  RecalcBottomMargin;
procedure TForm1.RecalcBottomMargin;
  function CountOccurences( const aSubText, aText: string): Integer;
    Result := Pos(aSubText, aText);
    if Result > 0 then
      Result := (Length(aText) - Length(StringReplace(aText, aSubText, '', [rfReplaceAll]))) div  Length(aSubtext);
var i, maxHeight, nLines, tmpMargin, tmpHeight: Integer;
  chrtSavingsNeeded.Draw;
  chrtSavingsNeeded.Canvas.Font.Assign(chrtSavingsNeeded.Axes.Bottom.Title.Font);
  maxHeight:=0;
  for i:=0 to chrtSavingsNeeded[0].Count-1 do
    nLines:=CountOccurences(#13, chrtSavingsNeeded[0].Labels[i]) + 1;
    maxHeight:= Max(maxHeight, nLines*chrtSavingsNeeded.Canvas.TextHeight(chrtSavingsNeeded[0].Labels[i]));
  tmpMargin:=maxHeight+chrtSavingsNeeded.Axes.Bottom.TickLength;
  if chrtSavingsNeeded.Axes.Bottom.Title.Visible or Assigned(FAnnTool) then
    if not Assigned(FAnnTool) then
      FAnnTool:=chrtSavingsNeeded.Tools.Add(TAnnotationTool) as TAnnotationTool;
    with FAnnTool do
      Text := chrtSavingsNeeded.Axes.Bottom.Title.Text;
      Shape.Assign(chrtSavingsNeeded.Axes.Bottom.Title);
      Left := chrtSavingsNeeded.Axes.Bottom.IStartPos+(chrtSavingsNeeded.Axes.Bottom.IAxisSize div 2) - (chrtSavingsNeeded.Canvas.TextWidth(Text) div 2);
      Top := chrtSavingsNeeded.Axes.Bottom.PosAxis+tmpMargin;
      tmpMargin := tmpMargin+chrtSavingsNeeded.Canvas.TextHeight(Text);
    chrtSavingsNeeded.Axes.Bottom.Title.Visible:=false;
  if chrtSavingsNeeded.Legend.Visible and (chrtSavingsNeeded.Legend.Alignment = laBottom) then
    chrtSavingsNeeded.Legend.CustomPosition:=true;
    chrtSavingsNeeded.Legend.Left:=(chrtSavingsNeeded.Width div 2) - (chrtSavingsNeeded.Legend.Width div 2);
    tmpHeight:=chrtSavingsNeeded.Legend.Height;
    chrtSavingsNeeded.Legend.Top:=chrtSavingsNeeded.Axes.Bottom.PosAxis+tmpMargin;
    tmpMargin:=tmpMargin+tmpHeight;
  chrtSavingsNeeded.MarginUnits:=muPixels;
  chrtSavingsNeeded.MarginBottom:=tmpMargin;
procedure TForm1.Resize;
  inherited;
  RecalcBottomMargin;
TestAlways
Post by TestAlways » Thu Oct 16, 2014 8:25 pm
Thank you for your responses.
If I use the Footer.Text property for my charts sub-title, the overlap still occurs. (I tried to change the code you wrote but could not get it to work with my new demo).
Ed Dressel
(2.63 KiB) Downloaded 980 times
Post by Narcís » Fri Oct 17, 2014 8:34 am
Hi Ed,
With the modifications David Berneda made to the code it's working fine now:
So you may expect this being fixed in the next maintenance release. If you are interested, you can also check David's new beta version here.
TestAlways
Post by TestAlways » Fri Oct 17, 2014 2:49 pm
It's difficult to release beta code to my end users--it doesn't go over very well when it doesn't work. How close is this to being a final release?
Post by Narcís » Mon Oct 20, 2014 6:59 am
Hello Ed,
TestAlways wrote:How close is this to being a final release?
We expect this version being out in about one month.
