TCursorTool issue with 2012.07.120914
It lloks like that I cannot set the initial XValue of the TCursorTool. Attached is a sample project file. Any hwlp would be mostly appreciated.
Kindest regards
Kindest regards
- project.zip
- (4.5 KiB) Downloaded 904 times
Re: TCursorTool issue with 2012.07.120914
This looks like a bug. Could you please add it to bugzilla? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
Hello Narcis,
I see now that the bug has been fixed but how can I implement this in my version?
Hi johnnix,
If I'm not wrong, your subscription expired on September 2012. To get TeeChart updates you should renew your subscription. The fix will be included in the next TeeChart maintenance release. We could also send the fix to source code customers with a valid subscription.
You are 100% right
Do I need to renew my subsrciption or upgrade?
Kindeste regards
![Smile :)](./images/smilies/icon_smile.gif)
Kindeste regards
Hi johnnix,
Not sure about those details. Please contact our Sales Dept. at sales at steema dot com.
Hello Narcis,
All taken care off!!! how can I have the fix for my current version (the one that appears on the subject)
Kindest regards
Kindest regards
Hello johnnix,
Ok, just sent you an email with fixed TeeTools.pas.
Hello Narcis,
Unfortunately I cannot use this as I am using the previous version of TChart
Hi johnnix,
Would you be interested in a complete source code test installer?
Hello Narcis,
I heavily use TChart in my applications and over the years some update changes altered the behavior of my plots. Since there is a change regarding GDI+ I am really sceptical regarding the installation of the latest version. I already modified my current chart tools code based on the latest version you sent me, I can set a custom value now (with a trick of course as the value cannot be set before the chart axis are drawn)
Hello johnnix,
In that case there's little I can do, I'm afraid. My recommendation would be that you set up a test environment with your IDE and the latest TeeChart version so that you can test and compare it with the version you currently use. That way you can gain confidence on it and consider if it's worth adopting the new version as the production environment. Alternatively, you can try using the new version directly and go back to the older version if it doesn't satisfy you.
