WhebJava
Post
by WhebJava » Mon Sep 05, 2011 7:27 pm
I'm trying to make the scroll arrow to go only where there is value in the series. In Delphi works with the lock, when the series finish.
I read in the tutorial 08 the instructions, but I could not.
I did something wrong?
The following code:
JFrame frame = new JFrame();
JPanel panel = new JPanel();
panel.setSize(600, 600);
TChart chart = new TChart();
chart.getAxes().getBottom().getLabels().setValueFormat("0");
panel.add(chart);
Bar bar = new Bar(chart.getChart());
for (int i = 0; i < 10; i++) {
bar.add(i);
AxisArrow axisDown = new AxisArrow(chart.getChart().getAxes().getBottom());
axisDown.setScrollInverted(false);
chart.getChart().getTools().add(axisDown);
chart.getAxes().getBottom().setAutomatic(false);
chart.getAxes().getBottom().setMinimum(0.0);
chart.getAxes().getBottom().setMaximum(10.0);
frame.add(panel);
frame.setSize(600, 600);
frame.setVisible(true);
Post
by Yeray » Tue Sep 06, 2011 2:31 pm
Are you sure you are doing the same in Delphi and in Java?
The following code, in Delphi, doesn't "lock" the axis for me here:
uses Series, TeeTools;
var i: Integer;
Chart1.View3D:=false;
with Chart1.AddSeries(TBarSeries) do
for i:=0 to 9 do
Add(i);
(Chart1.Tools.Add(TAxisArrowTool) as TAxisArrowTool).Axis:=Chart1.Axes.Bottom;
WhebJava
Post
by WhebJava » Thu Sep 08, 2011 11:32 am
I'm doing in Java.
I want to lock the scroll when it came to the limits of the series.
Post
by Yeray » Thu Sep 08, 2011 1:35 pm
WhebJava wrote:I'm doing in Java.
I understood you are trying to do it in Java, but I also understood you already achieved it in Delphi:
WhebJava wrote:In Delphi works with the lock, when the series finish.
So I was trying to see how did you do that in Delphi. I'd say it will probably be similar.
WhebJava
Post
by WhebJava » Mon Sep 12, 2011 7:37 pm
I translate from Delphi to Java, but it did not work as I wanted, so I asked here.
In java it does not block the scroll when the series ends.
It would be a problem? Or am I doing wrong?
Post
by Narcís » Tue Sep 13, 2011 10:46 am
Hi WhebJava,
Code below works fine for me here. Can you please check if it works fine at your end?
private void initChart() {
commander1.setChart(tChart1.getChart());
final Line l = new Line(tChart1.getChart());
l.fillSampleValues();
final AxisArrow axisDownLeft = new AxisArrow(tChart1.getChart().getAxes().getBottom());
axisDownLeft.setPosition(AxisArrowPosition.START);
final AxisArrow axisDownRight = new AxisArrow(tChart1.getChart().getAxes().getBottom());
axisDownRight.setPosition(AxisArrowPosition.END);
tChart1.addChartPaintListener( new ChartPaintAdapter() {
@Override
public void seriesPainted(ChartDrawEvent e) {
boolean leftActive = false;
boolean rightActive = false;
if (l.firstDisplayed() > 0) {
rightActive = true;
} else {
if (l.lastDisplayed() < l.getCount() - 1) {
leftActive = true;
} else {
leftActive = false;
axisDownLeft.setActive(leftActive);
axisDownRight.setActive(rightActive);
@Override
WhebJava
Post
by WhebJava » Tue Sep 13, 2011 4:19 pm
Hi Narcis,
It is something similar to what you did have to do.
I will make the necessary changes, thanks for the tips.
