Delph 2007 and Teetree2 included Teechart Pro VCL 8.04
I try change presentation of Tree by (Explorer, Left , Top or ListView) , at runtime but i have exception.
What is the best practice in this subject ??
My code ================================================================
function TreePrepareManager(ATree:TTree;AChildManager:TObject):integer;
if ATree=nil then exit;
try
// Typ de tree Explorateur ; top ; Left ; ListView (PB not ancestor common!!)
if (AChildManager is TTreeExplorerAlignChild) then
ATree.ChangeManager(AChildManager as TTreeExplorerAlignChild)
else if AChildManager is TTreeTopBottomAlignChild then
ATree.ChangeManager(AChildManager as TTreeTopBottomAlignChild)
else if AChildManager is TTreeLeftRightAlignChild then
ATree.ChangeManager(AChildManager as TTreeLeftRightAlignChild)
else if AChildManager is TTreeListViewAlignChild then
ATree.ChangeManager(AChildManager as TTreeListViewAlignChild);
Except
CT_ERR.Push('U_TreeEfc.pas : Procedure PrepareChildManager'); Raise; // exception vioalion access !!!
End;
in my forms========================================
constructor TFrameEfcTree.Create(AOwner: TComponent);
inherited;
// Format of the tree
ChildExplorateur :=TTreeExplorerAlignChild.Create;
ChildTop :=TTreeTopBottomAlignChild.Create;
ChildLeft :=TTreeLeftRightAlignChild.Create;
ChildList :=TTreeListViewAlignChild.Create;
Tree1.AssignParent:=True;
ChildEnCours := ChildExplorateur; // ChildEnCours is Tobject
procedure TFrameEfcTree.BtExploClick(Sender: TObject);
Tree1.Clear;
TreePrepareManager(Tree1, ChildEnCours );
procedure TFrameEfcTree.BtLeftClick(Sender: TObject);
Tree1.Clear;
ChildEnCours := ChildLeft;
But, in first test is OK, but if change 2 o 3 > exception !!
Change ChildManager at runtime
Re: Change ChildManager at runtime
Hi mivchart,
Could you please send us a simple example project we can run as-is to reproduce the problem here?
Ok, with sample project.
- ChildManager.zip
- Sample Example
- (32.92 KiB) Downloaded 976 times
Do you have solution for me, with example above !
Hi mivchart,
Thanks for the project. We could reproduce the problem and we tried to analyse what's wrong but I'm afraid we couldn't find it.
I've added it to the defect list to be revised deeper so it can be fixed in future releases (TV52014798).
ok,
ok, I'll do differently in this case
i have a solution to every change made in the format, you must recreate a ChilManger, without releasing the previous !
I think the release is done internally
It's simple and it works
I create a type to simplify my code
type TTreeFmtType=(TreeFmtExplo,TreeFmtTop,TreeFmtLeft,TreeFmtList);
procedure TFrameEfcTree.TreeChangeFormat;
try
//change la Forme du Tree
case TreeFormat of
TreeFmtExplo: Tree1.ChangeManager(TTreeExplorerAlignChild.Create);
TreeFmtTop: Tree1.ChangeManager(TTreeTopBottomAlignChild.Create);
TreeFmtLeft: Tree1.ChangeManager(TTreeLeftRightAlignChild.Create);
TreeFmtList: Tree1.ChangeManager(TTreeListViewAlignChild.Create);
end; //case
except
On E:Exception do Showmessage(E.Message);
try
case TreeFormat of
end; //case
except
