I am trying to delete a Shape in TMapSeries in code like (either one)
SeriesMap.Shapes.Free;
SeriesMap.Shapes.Polygon.Free;
which returns Error in runtime.
Manual deleting (select+delete kbd button) gives error in Tee8new either.
Is there any way to delete a certain shape in TMapSeries
(like SeriesMap.Delete)?
regards,
odissey1
Error on deleting a shape polygone in TMapSeries
Hi odissey1,
Yes, you can use Delete method, for example:
Or deleting all polygons:
Which is the equivalent of this:
Series1.Delete(0);
for i := Series1.Count-1 downto 0 do
Series1.Delete(i);
Series1.Clear;
-I am afraid not. At least not in my TeeChart v.7.12. Compiler say: 'There is no overload version of Series1.Delete(0)';narcis wrote:Hi odissey1,
Series1.Delete(0);
But something wrong in TeeChart 8.x also. Try to open Tee8new.exe -> MapGIS series -> Edit -> Shapes. Now select any shape with a mouse. Hit 'Delete' button on keyboard. You will get an error message.
Hi odissey1,
This works fine for me here using v8.04-I am afraid not. At least not in my TeeChart v.7.12. Compiler say: 'There is no overload version of Series1.Delete(0)';
I could reproduce this and added the issue to the defect list (TV52013644) to be investigated.But something wrong in TeeChart 8.x also. Try to open Tee8new.exe -> MapGIS series -> Edit -> Shapes. Now select any shape with a mouse. Hit 'Delete' button on keyboard. You will get an error message.
The Series.Delete(x) method deletes a specific shape from Map Series, and the method you're using Series.Shapes[x].Delete(start,end,removegaps) would remove all points from shape but wont remove (free) the shape created. it will remain there as a data point. The correct method to remove completely a specific shape is the Delete(x).
It's strange, I've just checked the latest TeeChart Pro VCL v7 sources and you should be able to use the Delete method, it exists since the earlier versions. You could check if TeeChart is correctly installed.-I am afraid not. At least not in my TeeChart v.7.12. Compiler say: 'There is no overload version of Series1.Delete(0)';
don't know if it's correct but this also works like delete i think
Series1.Shapes.Points.Delete(0,Series1.Shapes.Points.Count - 1,False);
am I right? Confused
Pep Jorge
http://support.steema.com
