I have a problem printing TChart objects. Here is my situation:
I have a C++ project in Borland Developer Studio which uses TCharts. These charts TeeCreateBitmap method is called to extract a bitmap object which is stored in a database for use in Crystal Reports.
The chart szies are very large (3000 x 3000), so that text and and font are in the right proportion.
![Image](http://farm3.static.flickr.com/2353/2121870963_db6e71263f.jpg)
This is what is expected
However, in some cases this causes an EOutOfResources occurs as these images are so large, in some cases 250mb. To try to get around this, I have tried to reduce the graph size, for example 1000 x 1000. The result is shown below:
![Image](http://farm3.static.flickr.com/2242/2121870927_e5ea417809.jpg)
As you can see, the proportions are all wrong in comparison to the previous chart
Is there a way to get a JPEG from the TChart? Or can I call some kind of method to get the quality I want, but not return a mammoth sized TBitmap? We are working with quite a lot of legacy code and I am sure there is good reason to make this images so large, but it is a real problem when we just want to extract a JPEG for printing.
