Hi, I would like to implement the following graph. Note that
the bottom axis shall be logarithmic.
http://www.osiris.no/jakob/graph.jpg
Best regards
/Jakob
How can I do this graph?
Hi Jakob,
you should be able to do this using the following code :
But, it seems to be a bug setting an Origin and Stacked style. I've added it on our defect list and a fix for it will be considered to inclusion for the next maintenance releases.
horizBar1.Marks.Visible = false;
horizBar2.Marks.Visible = false;
horizBar1.Add (3,"DiagnoseX");
horizBar1.Add (-2,"DiagnoseC");
horizBar1.Origin = 1;
horizBar2.Add (2,"DiagnoseX");
horizBar2.Add (-3,"DiagnoseC");
horizBar2.Origin = 1;
//tChart1.Axes.Bottom.Logarithmic = true;
horizBar2.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked;
Pep Jorge
http://support.steema.com
Yes, this is exactly what I had problem with! When is the next releas scheduled? Is there any other possibility to do this? I have a release coming up very soon.Pep wrote: But, it seems to be a bug setting an Origin and Stacked style. I've added it on our defect list and a fix for it will be considered to inclusion for the next maintenance releases.
Is there any way to have bars have several colors (like my example graph) without using stacked bars`?
/Jakob
- Site Admin
- Contact:
Hi --
You can try something similar to thisIs there any way to have bars have several colors (like my example graph) without using stacked bars`?
horizBar1.Add (3,1,"DiagnoseX", Color.Green);
horizBar1.Add (2,1,"DiagnoseX", Color.Red);
horizBar1.Add (-3,2,"DiagnoseC", Color.Green);
horizBar1.Add (-2,2,"DiagnoseC", Color.Red);
Build 1.1.1499.42325 was released on 9/Feb/2004, meaning that the next maintenance release should be available in May/June.When is the next releas scheduled?
Thank you!
http://groups.google.com
http://codenewsfast.com/
Thanks Chris.
But: Do you mean that I should use ony one HorizBar series for all my values? Or is it just a typo? However when I tried to use 2 HorizBars with 2 values each (with the same y-value) they appear fine in the graph, but only one of them gets there associated name printed on the left axis?
/Jakob
/Jakob
- Site Admin
- Contact:
Hi --
Did you run the code I sent you in my last message? Let me give it to you again without the typosDo you mean that I should use ony one HorizBar series for all my values? Or is it just a typo? However when I tried to use 2 HorizBars with 2 values each (with the same y-value) they appear fine in the graph, but only one of them gets there associated name printed on the left axis?
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Thank you!
