Is there a way to display a label for a specific point?
Post by Pep » Thu Jan 08, 2004 12:38 pm
Yes, you can use the OnGetSeriesMark event to customize the text Marks and which you want to be showed :
For example using the following code will show only the max Mark :
			fastLine1.FillSampleValues(10);
			fastLine1.Marks.Visible = true;
		private void fastLine1_GetSeriesMark(Steema.TeeChart.Styles.Series series, Steema.TeeChart.Styles.GetSeriesMarkEventArgs e)
			if (series.YValues.Value[e.ValueIndex] != series.YValues.Maximum )
				e.MarkText = "";
Josep Lluis Jorge
http://support.steema.com
