Position setting of coordinate axis labels
Posted: Tue Oct 24, 2023 12:20 am
by 16055158
The above figure shows the position of the labels when Axis4. Labels. Angle=315
The following figure shows the position of the labels when Axis4. Labels. Angle=270
How to adjust the position of labels when Axis4. Labels. Angle=315 downwards and rightward
Re: Position setting of coordinate axis labels
Posted: Wed Oct 25, 2023 7:36 am
by ruben
Thanks for feedback. Which version of "TeeChart" and "Visual Studio" are you using?
Ruben
Posted: Wed Oct 25, 2023 7:41 am
by 16055158
TeeChart: Steema TeeChart for .NET Source Code 2017 4.1.2017.02140
VS2019 [ VB.NET ]
Posted: Mon Nov 20, 2023 12:49 am
by 16055158
VS2019 [ VB.NET +.NET Framework 4.6.2 ]
I am a legitimate registered user of Steema TeeChart for NET Source Code 2017 4.1.2017.02140. I purchased this version for $2400 at that time. I have been asking for a month now. Can the official answer my question
Posted: Mon Nov 20, 2023 7:41 am
by Marc
Apologies for the delay replying. Currently, non-regular angles, (not 0,90,180,270), are not correctly rendering distance from the axis. We are reviewing the code related to this area.
Posted: Tue Nov 21, 2023 6:15 pm
by Marc
The issue has been resolved (issues #2651]) and the solution will be included with the next TeeChart update.
I have ported this code back into the relevant method for the sourcecode version, 4.1.2017.02140, and although I am unable to test all possible usage scenarios for this version, it should work for you if you replace this entire method in the Axis.cs unit.:
DrawAxisLabel(ChartFont f, int x, int y, int angle, string st, TextShape format, bool isTitle)
Code for the method:
    /// <summary>
    /// Draws Axis Label (string) in font f at specified X,Y co-ordinate at Angle.
    /// </summary>
#if WPF || SILVERLIGHT || STORE
    protected internal void DrawAxisLabel(ChartFont f, double x, double y, int angle, string st, TextShape format, bool isTitle)
#else
    protected internal void DrawAxisLabel(ChartFont f, int x, int y, int angle, string st, TextShape format, bool isTitle)
#endif
      bool is3D = chart.aspect.view3D;
      TextAlignment tmpAlign, tmpAlign2;
      Drawing.Graphics3D g = chart.graphics3D;
      TextAlignment OldStrAlign = g.TextAlign;
#else
      StringAlignment tmpAlign, tmpAlign2;
      StringAlignment OldStrAlign = g.TextAlign;
#endif
      if (format == null)
        format = Labels;
        f = format.Font;
      g.Font = f;
      int intHorizontal = horizontal ? 1 : 0;
      int intOtherSide = otherSide ? 1 : 0;
      int notIntOtherSide = otherSide ? 0 : 1;
      int tmpFontHeight = g.FontHeight;
      double tmpH = tmpFontHeight / 2;
      double tmpZ = iZPos;
#else
      int tmpH = tmpFontHeight / 2;
      int tmpZ = iZPos;
#endif
      int n = NumTextLines(st);
      int delta = tmpFontHeight;
      if (horizontal && otherSide)
        if ((isTitle) && (is3D) && (!chart.aspect.orthogonal))
          tmpZ = MaxLabelsWidth() + chart.aspect.Width3D;
        if ((angle > 90) && (angle <= 180))
          y = isTitle ? y : y + delta;
          tmpAlign = TextAlignment.Center;
#else
          tmpAlign = StringAlignment.Center;
#endif
        else if ((angle > 0) && (angle <= 90))
          x = isTitle ? x : x - delta;
          if (!isTitle) x = x - (delta * (n) / 2);
          if (this.Labels.Align == AxisLabelAlign.Default)
            tmpAlign = TextAlignment.Left;
#else
            tmpAlign = StringAlignment.Near;
#endif
            y = y - this.MaxLabelsWidth();
            tmpAlign = TextAlignment.Right;
#else
            tmpAlign = StringAlignment.Far;
#endif
        else if ((angle > 180) && (angle <= 270))
          if (!isTitle) x = x + delta + (delta * (n) / 2);
#else
#endif
#else
#endif
          y = y - delta * (n + 1);
#else
#endif
      else if (horizontal)
          tmpZ = -MaxLabelsWidth();
#if WPF || SILVERLIGHT || STORE || PORTABLE
#else
          if (Labels.Align == AxisLabelAlign.Default)
            y += MaxLabelsWidth();
#endif
          x = x - delta;
          x = x - (delta * (n) / 4);
#else
#endif
            y = y + this.MaxLabelsWidth();
#else
#endif
#else
#endif
#else
#endif
        else if (angle == 0)
          y = y - delta;
#else
#endif
#if iOS
            if (!isTitle)
#endif
#elif ANDROID
          tmpAlign = Android.Graphics.Paint.Align.Center;
#elif iOS
          tmpAlign = CTTextAlignment.Center;
#else
#endif
      else if (otherSide)
          tmpZ = chart.aspect.Width3D + MaxLabelsWidth();
        if (angle == 0)
          y -= delta;
          y -= (delta * (n)) / 2;
#else
#endif
            x = x + this.MaxLabelsWidth();
#else
#endif
        else if ((angle > 270) && (angle < 360))
        else if ((angle > 90) && (angle <= 180))
          y += delta;
          y += (delta * (n)) / 2;
#else
#endif
#else
#endif
          x -= delta;
#else
#endif
          x += delta * (n + 1);
#else
#endif
        if (((angle > 270) && (angle <= 360)) || (angle == 0))
          y -= delta;
#else
#endif
            x = x - this.MaxLabelsWidth();
#else
#endif
        else if ((angle > 270) && (angle <= 360))
#else
#endif
#else
#endif
          y += delta;
#else
#endif
#else
#endif
          x -= delta * (n + 1);
#else
#endif
          x += delta;
#else
#endif
      int tmpNum;
      int tmpSize = Utils.Round(g.TextWidth("W") / 4.0F);  //4 instead 2 so the margin don't be so high
      format.Left = x;
      format.Top = y + delta;
      double tmpW = chart.MultiLineTextWidth(st, out tmpNum, format.TextFormat == TextFormat.Html);
#else
      int tmpW = chart.MultiLineTextWidth(st, out tmpNum, format.TextFormat == TextFormat.Html);
#endif
      tmpH = tmpFontHeight * tmpNum;
      tmpAlign2 = tmpAlign;
      format.Bottom = format.Top + tmpH;
      format.Right = format.Left + tmpW;
      if (tmpAlign2 == TextAlignment.Right)
#else
      if (tmpAlign2 == StringAlignment.Far)
#endif
        format.Right = format.Left;
        format.Left = format.Right - tmpW;
      else if (tmpAlign2 == TextAlignment.Center)
#else
      else if (tmpAlign2 == StringAlignment.Center)
#endif
        tmpW = (format.Right - format.Left) / 2;
        format.Right -= tmpW;
        format.Left -= tmpW;
      format.Left -= tmpSize;
      format.Right += tmpSize / 2;
      if (tmpZ != 0) format.ShapeBounds = g.CalcRect3D(format.ShapeBounds, tmpZ);
#if !WPF && !SILVERLIGHT && !STORE
      int tmpFT = format.Top;
      int tmpFH = format.Height;
#else
      double tmpFT = format.Top;
      double tmpFH = format.Height;
#endif
      bool tmpDraw = true;
      g.TextAlign = tmpAlign;
      int tmpD = delta * n;
      string tmpSt = st;
      int i;
      string tmpSt2 = "";
#if VS2005 && !WPF && !SILVERLIGHT && !REPORTINGSERVICES && !POCKET && !CLIENTPROFILE && !STORE
      if ((horizontal) && ((this.chart.Tools.Count > 0) && (hasScrollTool())))
        g.ClipRectangle(CalcXPosValue(minimumValue), 0,
                        CalcXPosValue(maximumValue), Chart.Height);
#endif
      DoGetAxisDrawLabel(this, ref x, ref y, ref tmpZ, ref tmpSt, ref tmpDraw);
      if (tmpDraw) n = NumTextLines(tmpSt);
      if (tmpDraw)
        for (int tt = 1; tt <= n; tt++)
          double tmpAngle = format.Width / 2;
          if (OtherSide)
            tmpAngle = tmpAngle - 0.25 * format.Height;
          double tmpYDisp = tmpAngle * Math.Abs(Math.Sin(Utils.Deg2Rad(angle)));
          if (angle > 0)
            format.Bottom = tmpFT;
            format.Top = tmpFT + (int)tmpYDisp; // - tmpFH;
            if ((angle >= 0) && (angle <= 90))
#if iOS
              if (!isTitle)
#endif
              if (angle == 90)
                x += delta - (tmpFontHeight / 4);
                x += delta - (int)(tmpFontHeight / 4 * Math.Abs(Math.Sin(Utils.Deg2Rad(angle))));
              format.Left += delta;
              format.Right += delta;
              if (angle == 180)
                x -= format.Width / 2;
                x -= (int)(tmpFontHeight / 2 * Math.Abs(Math.Sin(Utils.Deg2Rad(angle))));
              y += (int)(tmpFontHeight * Math.Abs(Math.Cos(Utils.Deg2Rad(angle))));
              x -= delta;
              format.Left -= delta;
              format.Right -= delta;
              x += (int)(format.Width / 2 * Math.Abs(Math.Cos(Utils.Deg2Rad(angle))));
              y += (int)(format.Width / 2 * Math.Abs(Math.Sin(Utils.Deg2Rad(angle))));
              format.Top += delta;
              format.Bottom += delta;
          if (!format.Transparent || hasClicked)
#if SILVERLIGHT || WPF || STORE
            if (angle > 0)
              RotateTransform rotate = new RotateTransform();
              rotate.Angle = 360 - angle;
              rotate.CenterX = x;
              rotate.CenterY = y;
              double tmpFW = format.Width;
              format.Left += tmpFW / 2.0;
              format.Right += tmpFW / 2.0;
#if STORE
              format.ShapePolygonBounds = new Point[] { rotate.TransformPoint(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top)),
              rotate.TransformPoint(new Point(format.ShapeBounds.Right, format.ShapeBounds.Top)),
              rotate.TransformPoint(new Point(format.ShapeBounds.Right, format.ShapeBounds.Bottom)),
              rotate.TransformPoint(new Point(format.ShapeBounds.Left, format.ShapeBounds.Bottom)),
              rotate.TransformPoint(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top))};
#else
              format.ShapePolygonBounds = new Point[] { rotate.Transform(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top)),
              rotate.Transform(new Point(format.ShapeBounds.Right, format.ShapeBounds.Top)),
              rotate.Transform(new Point(format.ShapeBounds.Right, format.ShapeBounds.Bottom)),
              rotate.Transform(new Point(format.ShapeBounds.Left, format.ShapeBounds.Bottom)),
              rotate.Transform(new Point(format.ShapeBounds.Left, format.ShapeBounds.Top))};
#endif
              g.Brush = format.Brush;
              g.Pen = format.Pen;
              g.Polygon(format.ShapePolygonBounds);
              format.DrawRectRotated(g, format.ShapeBounds, 0, tmpZ);
#elif !POCKET
            Matrix m = g.GDIplusCanvas.Transform;
            m.RotateAt((float)(360 - angle), new Point(x, y));
            g.GDIplusCanvas.MultiplyTransform(m);
            format.ShapePolygonBounds = new Point[] { new Point(format.ShapeBounds.Left, format.ShapeBounds.Top), new Point(format.ShapeBounds.Right, format.ShapeBounds.Top),
                new Point(format.ShapeBounds.Right, format.ShapeBounds.Bottom), new Point(format.ShapeBounds.Left, format.ShapeBounds.Bottom), new Point(format.ShapeBounds.Left, format.ShapeBounds.Top)};
            m.TransformPoints(format.ShapePolygonBounds);
            g.GDIplusCanvas.ResetTransform();
#endif
            labels.labelPos.Add(format.ShapePolygonBounds);
            labels.labelPos.Add(format.ShapeBounds);
          i = tmpSt.IndexOf(Texts.LineSeparator);
          tmpSt2 = (i != -1) ? tmpSt.Substring(0, i) : tmpSt;
          if (angle == 0)
            y += delta;
            g.Font = f;
            if (labels.Exponent)
              DrawExponentLabel(x, y, tmpZ, tmpSt2, angle);
            else if (is3D)
              g.TextOut(x, y, tmpZ, tmpSt2, format.TextFormat == TextFormat.Html);
              g.TextOut(f, x, y, tmpSt2, format.TextFormat == TextFormat.Html);
            if (labels.Exponent && (angle == 90 || angle == 270))
              g.RotateLabel(x, y, tmpZ, tmpSt2, angle, format.TextFormat == TextFormat.Html);
          if (i >= 0) tmpSt = tmpSt.Remove(0, i + 1);
      g.TextAlign = OldStrAlign;
Alternatively, you can upgrade to the latest version of TeeChart to access the modification directly.
