Import.Template.Load not working properly
Posted: Fri Sep 28, 2018 2:10 pm
by 15682814
I'm trying to save the config of 3 charts in the registry when the application closes. i have an issue that amongst other things [ but an obvious one ] if I have set the bottom axis to be auto scaled, you can see it is set to auto if you inspect it, then export a stream, rewind the stream and re-import it to the same chart, the axis is no longer auto
if I do the following:
frm.tcAmGraph.Axes.Bottom.Automatic
[true]
var stream3 = new MemoryStream();
frm.tcAmGraph.Export.Template.IncludeData = false;
frm.tcAmGraph.Export.Template.Save(stream3);
stream3.Position = 0;
frm.tcAmGraph.Import.Template.Load(stream3);
[false]
what am i missing?
thanks
Andy
Re: Import.Template.Load not working properly
Posted: Mon Oct 01, 2018 7:20 am
by Christopher
Hello Andy,
using the latest publicly available version of TeeChart.dll (4.1.2018.05040) I cannot reproduce this issue:
- 2018-10-01_09-11-07.jpg (53.75 KiB) Viewed 12820 times
which version of TeeChart.dll are you using?
Posted: Mon Oct 01, 2018 10:57 am
by 15682814
v4.0.30319
will get the latest and try again
Posted: Mon Oct 01, 2018 4:16 pm
by 15682814
I was wrong it was the latest
i'm more puzzled now
if i use the editor dialog to save out a .ten file of the chart ( with 1 fast line series and it's colour set to red ) and then
tcFmGraph.Import.Template.LoadFileDialog();
to load that file back in, the red trace goes back to the default blue trace ( application not stopped in between )
what am I missing? have attached the .ten file for anyones bemusement
Posted: Tue Oct 02, 2018 6:13 am
by Christopher
using the following code:
CreateCharts();
InitializeChart();
private TChart tChart1, tChart2;
FastLine fastLine = new FastLine(tChart1.Chart);
fastLine.FillSampleValues();
fastLine.Color = Color.Red;
MemoryStream stream = new MemoryStream();
tChart1.Export.Template.Save(stream);
stream.Position = 0;
tChart2.Import.Template.Load(stream);
private void CreateCharts()
tChart1 = new TChart();
tChart2 = new TChart();
tChart2.Dock = DockStyle.Fill;
tChart1.Header.Text = Utils.Version;
splitContainer2.Panel1.Controls.Add(tChart1);
splitContainer2.Panel2.Controls.Add(tChart2);
I obtain the following result:
- 2018-10-02_08-11-03.gif (38.52 KiB) Viewed 12808 times
here the FastLine series color does not seem to be affected by template exportation and importation.
