When I plot data in the chart, the title name goes out of the chart and you can not read it.
The same happens with the variables or labels assigned to the axis.
Is there any way to make TeeChart to respect the text adapting the chart size to it in order to fit everything and make it readable?
Thank you.
Title names and axis variable names out of the chart with TeeChart for .Net
- tChartMain.png (15.8 KiB) Viewed 10463 times
- image-20230620-123457.png (32.01 KiB) Viewed 10463 times
- Guru
Re: Title names and axis variable names out of the chart with TeeChart for .Net
By turning off a default speed optimization to stop the unnecessary recalculation of label sizes, I think you can achieve what you want, e.g.
bar.Add(1, "A long label for bar one");
bar.Add(10, "A long label for bar one");
tChart1.Axes.Bottom.FixedLabelSize = false;
tChart1.Axes.Bottom.Labels.Angle = 45;
