//Bug Report [+solution] TMapSeries.onClick
odissey1
Post by odissey1 » Tue Dec 09, 2008 2:59 am
I am working with TMapSeries drawing numerous balloons on the chart. I noticed that if some of the top shapes are made invisible, then they are still clickable, which is wrong, as they obstruct underlying shape objects.
Please find below corrected code for Clicked(..) function. Please note that while this code is for TeeChart 7.12, TC8.x still has this bug (can see it in Tee8new.exe).
regards,
odissey1
// Tee Bug with TMapSeries (clicked invisible polygons)
// TeeChart 7.12->
unit TeeMapSeries;
function TMapSeries.Clicked(x, y: Integer): Integer;
var tmpClip : Boolean;
    tmpRect : TRect;
  function IsShapeVisible(Shape:TPolygonSeries):Boolean;
  var tmp  : Integer;
      tmp2 : Integer;
//correction->
//or:    if not Shape.Polygon.Points.Visible then begin
    if not Shape.Visible then begin
       result:=False;
       Exit;
//<-correction
    if tmpClip then
    end
    else result:=True;
Post by Narcís » Tue Dec 09, 2008 12:24 pm
Hi odissey,
Thanks for your suggestion. I've added it to the wish-list to be considered for inclusion in future releases.
