Trouble with LoadChartFromFile
ludovico
Post by ludovico » Sat May 31, 2008 4:20 pm
I am using TeeChart v5.03 in Borland C++ Builder v6 and cannot successfully save and load a vertical bar chart at runtime.
I include TeeSource.hpp, and the SaveChartToFile seems to complete alright (although I am not using a .tee extension), but when I try to load the chart I get an error that says that the Class TBarSeries not found.
I have set the IncludeData param to TRUE and would really like to load the entire bar chart.
Does this routine work correctly in v5.03 of TeeChart
Post by Narcís » Mon Jun 02, 2008 7:51 am
Hi ludovico,
Your problem is likely to be the same as described here.
xxxxxx
Post by xxxxxx » Mon Jun 02, 2008 5:23 pm
I'm afraid ludovico has TeeChart Standard and TeeEditPro is not available to him. He may need use RegisterClass(TBarSeries) call.
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Post by Narcís » Mon Jun 02, 2008 6:42 pm
Hi Alexander,
No, it doesn't exist a Standard version of TeeChart v5 VCL, only a Pro version exists. Standard versions are the ones shipped with Borland/CodeGear products. Also a retail version was made starting at TeeChart v7 VCL. Until BDS 2006 all Delphi and C++ Builder versions included TeeChart v4 Standard.
