Pie chart slices to do not update (D2007, TC v7.11 Pro)
Dan
Post by Dan » Tue Feb 19, 2008 5:26 am
The slices of the pie chart do not update in D2007 TC7.11 PRO. The AddPie function works to initially add slices to the chart, but then updates to the values are not reflected except by the chart labels and legend.
This occurs in code and through the chart editor in both run and design times, and on several computers.
Plugging in a bar chart into the same form/code (changing the addpie call to addbar) works fine.
The code was recently migrated from Delphi 7 (TC 7.04 PRO) where it was working and stable for a number of years.
Delphi version - 11.0.2709.7128
Platform - XP SP2
I've tried quite a few tacts to try and work this one out so any help/advice would be greatly appreciated.
Daniel
Post by Narcís » Tue Feb 19, 2008 9:36 am
Hi Daniel,
I could reproduce the issue here using v7.12 and this code:
var i: Integer;
  for i:=1 to 5 do
    Series1.AddPie(i);
  Series1.AddPie(random*10);
I've also checked that this code works fine with TeeChart Pro v8 VCL.
Dan
Post by Dan » Tue Feb 19, 2008 9:28 pm
Thanks for the prompt reply.
Will there be a patch for version 7.12?
Post by Narcís » Wed Feb 20, 2008 9:33 am
Hi Dan,
I think it's most unlikely that a new TeeChart v7 release will be published.
achristouio
Post by achristouio » Wed Feb 20, 2008 11:04 am
narcis wrote:Hi Daniel,
var i: Integer;
  for i:=1 to 5 do
    Series1.AddPie(i);
The code works in Delphi 2006, but this did not work:
var i: Integer;
for i:=1 to 5 do
Series1.AddPie(i);
update;
Could it be verified that this code works in v. 8?
Post by Narcís » Wed Feb 20, 2008 11:11 am
Hi achristouio,
Yes, I've checked that this works fine using v8.
Dan
Post by Dan » Thu Feb 21, 2008 12:08 pm
I would expect that an update or patch is released. Steema has released an update that has stopped the pie chart from working entirely. I'm not seeking new functionality (which might warrant an upgrade to the next major release). I'm just expecting that previously working v7 functionality be fixed so that it is working again.
Daniel
Post by Narcís » Fri Feb 22, 2008 11:55 am
Hello Daniel,
We have just posted an update build for Delphi 2007 fixing this issue at the client area.
Dan
Post by Dan » Fri Feb 29, 2008 2:50 am
Thanks Narcís,
It all works now - I'm grateful to you and the Steema team for fixing this issue,
Daniel
Post by Narcís » Fri Feb 29, 2008 8:18 am
Hi Daniel,
You're welcome. I'm glad to hear that.
