TeeChart 7 Source Code Installation
Posted: Fri Apr 20, 2007 11:40 am
by 9345875
Hi, I would appreciate if you can clarify a few things about TeeChart installations. I'm a Teechart Pro user (including source code).
Questions:
- what is the recommended installation: install both binary package and source package ? What should be installed first? Where to install source code.
- if I recompile source code, I get duplicated BPL libraries, should precompiled be deleted
- is it enough just to install source code and recompile packages
- what happens if I have several Delphi installations on same computer (Delphi 7, Delphi 2006, Delphi 2007). Should every binary package be installed in separate folder. Is it enough to install one source package and then recompile for every Delphi version.
Thanks for help.
Posted: Fri Apr 20, 2007 1:48 pm
by narcis
Hi matjazu,
Please find below the answers to your questions.
We recommend to install both. First install the binary installer to obtain the examples and documentation included in it and then install the source code. It doesn't matter where you install the source code, this may depend on where you like 3rd party components files located. Anyway, it's also fine using default installation path.
This shouldn't be a problem provided that your Delphi points to the newly compiled files on TOP of its search path list at Project -> Options -> Directories/Conditionals.
It is enough to be able to work with TeeChart but you won't have any example nor documentation. That's why we recommend to install both versions.
You can install using the binary installer for each IDE or not. In your case I'd recommend you to install the binary installer for Delphi 7 for the reasons I told you before and then install TeeChart to the other IDEs using Recompile tool provided with the source code installer. In that case, Delphi 7 will be already linked to the help files. D2006 and D2007 won't because TeeChart help file system hasn't been made compatible with html help files.
Posted: Tue Apr 24, 2007 12:50 pm
by 5891343
I would hope it could be made a ressoruce for what files is needed to be removed in the different directories when installing TeeChart on a newly installed compiler which also has with it the precompiled teechart.
I removed now the dclTee.* and tee*.*^from all directories I found them, but still installer complained about files in lib directory.
Is it the registry that sould be cleaned for any mention of files or is there some dcu-files not starting with tee*.* in the lib that should have been removed.
Difficult to know then what should be removed since I'm somewhat visually impaired due to both retinopathy and cataract :-(
Posted: Fri Apr 27, 2007 6:44 am
by Pep
Hi Alf,
I'm not sure which is the status of the installation at this moment, have you installed the v7.11 using the binaries installer ?
If so, are you able to create a simple project adding aTChart object and compile it ?
If so, just one more thing should be done, it's add the path where the TeeChart Pro v7.11 has been installed (the \Source path) to the "Search path", and "Debug path", to allow you to debug and update the source code if needed.
