Installing from source: TVisualBlock undefined
Optimeas
Post by Optimeas » Sat Jul 29, 2023 3:33 pm
I've just updated from 2023.37 to 2023.38 and I'm not able to compile the sources: when I try to compile the package TeeMaker128.bpl then I get an exception because the class TVisualBlock is undefined. I found this class in the documentation; should be in TeCanvas but the TeCanvas you give in the installation does not have any TVisualBlock defined.
Could you please check the sources?
thx
Re: Installing from source: TVisualBlock undefined
Post by Yeray » Mon Jul 31, 2023 10:50 am
We moved TVisualBlock class from TeCanvas.pas unit to TeeBlocks.pas unit in v2023.38.
We may need to correct the documentation. Were did you find that?
Optimeas
Post by Optimeas » Tue Aug 08, 2023 7:55 am
we have an automatic build process for all VCLs packages we buy. This is the reason why we always buy components with sources, this is a quality requierment. Please provide us the corrected source for v2023.38.Thanks
Post by Marc » Fri Aug 11, 2023 11:08 am
We are checking the source-control related to TeeMaker and will make the fix available, Apologies for the inconvenience.
Post by Yeray » Wed Aug 23, 2023 8:12 am
We've just open sourced TeeMaker (find it here) and we've removed it from TeeRecompile (this will be available in the next release).
