In my previous topic, I was asking about the correct horizontal placement of a title above a self-stacked bar chart. In this post, I would like to be able to set the vertical position of the title just above the top axis of the bar chart, and have it remain there on scroll or zoom operations. As shown in the attached images, the title scrolls off the top of the chart at present if I use CalcBarBounds, or disappear entirely if I zoom the chart.
Any suggestions much appreciated.
Best regards
Errol
Bar Chart self-stacked title vertical position
- BarChart unscrolled.jpg (106.02 KiB) Viewed 3504 times
- BarChart scrolled up.jpg (105.05 KiB) Viewed 3504 times
- BarChart zoomed.jpg (106.93 KiB) Viewed 3504 times
Re: Bar Chart self-stacked title vertical position
Taking the code from the reply I just wrote there, I've modified it to also calculate the value for the
TAnnotationTool.Top
property to position them just above the ChartRect
:Code: Select all
uses Series, TeeTools;
const aWellName: array[0..2] of string = ('AT-602', 'AT-501', 'AT-401');
var i, j: Integer;
Chart1.Title.Hide;
Chart1.View3D:=False;
Chart1.Color:=clWhite;
Chart1.Legend.Hide;
for i:=0 to 2 do
MultiBar:=mbSelfStack;
Marks.Hide;
for j:=0 to 4 do
Add(5+Random*5);
with TAnnotationTool(Chart1.Tools.Add(TAnnotationTool)) do
Shape.CustomPosition := true;
Shape.Pen.Color := clWhite;
Shape.Transparent := true;
Shape.Font.Size := 10;
Shape.Font.Style := Shape.Font.Style + [fsBold];
Shape.Angle := 90;
Text := aWellName[i];
OnBeforeDraw:=AnnotationToolBeforeDraw;
Chart1.MarginTop:=10;
Chart1.Draw;
procedure TForm1.AnnotationToolBeforeDraw(Sender: TObject);
var i: Integer;
for i:=0 to Chart1.Tools.Count-1 do
if Sender = Chart1.Tools[i] then
PlaceWellNames(i);
Exit;
procedure TForm1.PlaceWellNames(AIndex: Integer);
var
LLeft, LWidth: integer;
LAcross: integer;
annot: TAnnotationTool;
bar: TBarSeries;
if Chart1.Tools[AIndex] is TAnnotationTool then
annot:=TAnnotationTool(Chart1.Tools[AIndex]);
bar:=TBarSeries(Chart1[AIndex]);
// centre of bar
LLeft := bar.CalcXPos(0) + (bar.BarWidth div 2);
LWidth := annot.Width; // width of shape
LAcross := LWidth div 2; // half title width
annot.PositionUnits := muPixels;
annot.Left := LLeft - LAcross; // this is correct for non-automatic scaling
annot.Top := Chart1.ChartRect.Top - LAcross - 10;
