I made a very simple test with only a tTree included in the test project. Which fail as shown in the zip file included
Source and screen dumps are in the documentfolder
There is also included a few text files with the setup of compiler
Seems like tTree is not visible to the compiler.
Hope there is a simple solution to this.
After installing TeeChartVCL2010H2Help.zip tTree isn't recognize using 10.3.0
- Steema ttree tester.zip
- (394.32 KiB) Downloaded 784 times
Re: After installing TeeChartVCL2010H2Help.zip tTree isn't recognize using 10.3.0
Seems like solved.
Installation didn't populate VCLTee as Unit scope name
