Overlapping marks
Test Always
Overlapping marks
Post by Test Always » Wed Aug 30, 2017 9:02 pm
In an application I write, I use marks to explain what the bars stand for, but sometimes, the marks disappear, I guess because there is not enough room for them without overlapping. In the financial services industry I work, it is a big problem not to label everything.
Here is an example:
The mark for the middle bar gets dropped--in this case, there should be little (if any) overlap with the labels on either side. (It should have "Current" and the dollar value on it).
In any case, is there any way to stop the marks from disappearing?
Thank you,
Edward Dressel
Re: Overlapping marks
Post by Yeray » Thu Aug 31, 2017 9:22 am
Hello Ed,
You can disable it with Marks.Automatic.Move property:
  Series1.Marks.Automatic.Move:=False;
