TChart.AdjustMinMax wrong for inverted axis
Toreba
Post by Toreba » Thu Oct 29, 2015 7:44 am
I am using TeeChart Pro 2013.09.131119 32-bit VCL in Delphi XE5.
I create a TChart with an inverted non-automatic left axis. Adding more series and I then need to reset the extents of the non-automatic axis. To get the extents of the data plotted so far I execute these two lines:
TargetAxis.Automatic:=True;
TargetAxis.AdjustMaxMin;
Then, left axis minimum is reported to be -99999, though the minimum data value is zero.
This error occurs only if the axis is inverted.
Is this a bug?
Toreba
Re: TChart.AdjustMinMax wrong for inverted axis
Post by Yeray » Fri Oct 30, 2015 4:45 pm
Hello Toreba,
This seems to work fine both with TeeChart v2013.09 and the actual v2015.16:
uses Series, TeeConst;
  Caption:=TeeMsg_Version;
  Chart1.AddSeries(TLineSeries).FillSampleValues(10);
  Chart1.Axes.Bottom.Inverted:=true;
  Chart1.Axes.Bottom.SetMinMax(0, 12);
var i: Integer;
  with Chart1.AddSeries(TLineSeries) do
    Add(50+random*100);
    for i:=1 to 20-1 do
      Add(YValue[i-1]+random*10+5);
  Chart1.Axes.Bottom.Automatic:=true;
I may be missing some relevant setting to reproduce the problem.
