TChart Pro 2015.14.150120 32 bit VCL
See the attached demo that raises an exception as soon as the "Update Chart" button is clicked. The button simply creates a series for the chart but doesn't add any data to the series.
I have Pro version, and need to get this fixed so I can get it out to my customers. I would appreciate a code fix.
Ed Dressel
AV after creating horizontal series with no values
- Advanced
- AV on Horz Series.zip
- (1.94 KiB) Downloaded 757 times
Re: AV after creating horizontal series with no values
Hi Ed,
This bug was already found and fixed.
I've added it to the public tracker so other customers can find it if they try to report it:
http://bugs.teechart.net/show_bug.cgi?id=1106
The fix is, at Chart.pas, where says:
Change it for this:
function TCustomChartLegend.CalcItemWidth(const ACol,AIndex:Integer):Integer;
var tmpSt : String;
tmpLines : Integer;
if FItems.Custom and (FItems.Count>AIndex-FirstValue) then
if ACol=0 then
tmpSt:=FItems[AIndex-FirstValue].FText
tmpSt:=FItems[AIndex-FirstValue].FText2
tmpSt:=IItems[AIndex-FirstValue,ACol];
if tmpSt='' then
result:=0
result:=ParentChart.MultiLineTextWidth(tmpSt,tmpLines,TextFormat)+FTextSymbolGap;
var tmpSt : String;
tmpLines : Integer;
if ACol=0 then
else if (Length(IItems)>0) then
tmpSt:= '';
if tmpSt='' then
result:=0
- Advanced
Thank you.
Is there any way to get a list of patches for 2015.14? This would be embarrassing if our internal testing did not pick this up and a customer did. If there are other items like this, I would like to get them fixed.
Thank you,
Ed Dressel
Thank you,
Ed Dressel
Hi Ed,
I'm not sure to understand what do you exactly mean.
Bugzilla allows you to do customizable searches like:
- Tickets created after 20th January 2015, when v2015.14 was published: link
- Tickets closed as "fixed" since 20th January 2015, when v2015.14 was published: link
