Series Caption and Legend Overlap
Posted: Mon Oct 06, 2014 9:05 pm
by 10546565
XE2, TeeChart Pro 2014.11 04.09
In the attached demo, the series caption and legend overlap. If it is vertically enlarged, the problem does not occur--but I don't want to waist vertical spacing.
Is there a way that fixes this that doesn't waist vertical spacing?
Ed Dressel
Re: Series Caption and Legend Overlap
Posted: Tue Oct 07, 2014 9:36 am
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=947
In the meanwhile, you could use a TAnnotationTool instead of using the bottom axis title, and recalculate the margin on the bottom manually. Ie:
uses Series, Math, TeeTools;
var bottomTitle: TAnnotationTool;
var i: Integer;
Chart1.Align:=alClient;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
FillSampleValues();
Marks.Visible:=false;
for i:=0 to Count-1 do
Labels[i]:=FormatFloat('#0.##', YValue[i]) + #13 + 'Extra Line 1' + #13 + 'Extra Line 2';
Chart1.Axes.Bottom.Title.Text:='Bottom Axis Title';
recalcBottomMargin;
procedure TForm1.Chart1Resize(Sender: TObject);
recalcBottomMargin;
procedure TForm1.recalcBottomMargin;
function CountOccurences( const SubText: string;
const Text: string): Integer;
Result := Pos(SubText, Text);
if Result > 0 then
Result := (Length(Text) - Length(StringReplace(Text, SubText, '', [rfReplaceAll]))) div Length(subtext);
var i, maxHeight, nLines, tmpMargin: Integer;
Chart1.Draw;
maxHeight:=0;
for i:=0 to Chart1[0].Count-1 do
nLines:=CountOccurences(#13, Chart1[0].Labels[i]) + 1;
maxHeight:=Max(maxHeight, nLines*Chart1.Canvas.TextHeight(Chart1[0].Labels[i]));
tmpMargin:=maxHeight;
if Chart1.Axes.Bottom.Title.Visible or Assigned(bottomTitle) then
if not Assigned(bottomTitle) then
bottomTitle:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
with bottomTitle do
Text:=Chart1.Axes.Bottom.Title.Text;
Shape.Assign(Chart1.Axes.Bottom.Title);
Left:=Chart1.Axes.Bottom.IStartPos+(Chart1.Axes.Bottom.IAxisSize div 2) - (Chart1.Canvas.TextWidth(Text) div 2);
tmpMargin:=Chart1.Axes.Bottom.TickLength+maxHeight+Chart1.Canvas.TextHeight(Text);
Top:=Chart1.Axes.Bottom.PosAxis+tmpMargin;
Chart1.MarginBottom:=tmpMargin;
Chart1.Axes.Bottom.Title.Visible:=false;
Chart1.MarginUnits:=muPixels;
Posted: Tue Oct 07, 2014 2:05 pm
by 10546565
Thank you for your response.
I merged your code with my demo and the problem still occurs--the problem for me was legend overlap with captions. See the attached demo.
Is there a work around?
Ed Dressel
Posted: Tue Oct 07, 2014 3:14 pm
Hi Ed,
You can do something similar than what I was doing, setting the legend to be in the bottom though a custom position and adding the necessary margin to the bottom:
constructor TForm1.Create(aOwner: TComponent);
var
I: Integer;
lValue: Double;
lCaption: string;
inherited;
FAnnTool := nil;
lValue := 100;
for I := 1 to 5 do
lValue := lValue * (1 + (Random * 0.2));
lCaption := inttostr(I);
if I = 3 then
lCaption := lCaption + #13 + 'Extra Caption Line';
Series1.AddBar(lValue, lCaption, clTeeColor);
chrtSavingsNeeded.Axes.Bottom.Title.Text:='Bottom Axis Title';
RecalcBottomMargin;
procedure TForm1.RecalcBottomMargin;
function CountOccurences( const aSubText, aText: string): Integer;
Result := Pos(aSubText, aText);
if Result > 0 then
Result := (Length(aText) - Length(StringReplace(aText, aSubText, '', [rfReplaceAll]))) div Length(aSubtext);
var i, maxHeight, nLines, tmpMargin, tmpHeight: Integer;
chrtSavingsNeeded.Draw;
chrtSavingsNeeded.Canvas.Font.Assign(chrtSavingsNeeded.Axes.Bottom.Title.Font);
maxHeight:=0;
for i:=0 to chrtSavingsNeeded[0].Count-1 do
nLines:=CountOccurences(#13, chrtSavingsNeeded[0].Labels[i]) + 1;
maxHeight:= Max(maxHeight, nLines*chrtSavingsNeeded.Canvas.TextHeight(chrtSavingsNeeded[0].Labels[i]));
tmpMargin:=maxHeight+chrtSavingsNeeded.Axes.Bottom.TickLength;
if chrtSavingsNeeded.Axes.Bottom.Title.Visible or Assigned(FAnnTool) then
if not Assigned(FAnnTool) then
FAnnTool:=chrtSavingsNeeded.Tools.Add(TAnnotationTool) as TAnnotationTool;
with FAnnTool do
Text := chrtSavingsNeeded.Axes.Bottom.Title.Text;
Shape.Assign(chrtSavingsNeeded.Axes.Bottom.Title);
Left := chrtSavingsNeeded.Axes.Bottom.IStartPos+(chrtSavingsNeeded.Axes.Bottom.IAxisSize div 2) - (chrtSavingsNeeded.Canvas.TextWidth(Text) div 2);
Top := chrtSavingsNeeded.Axes.Bottom.PosAxis+tmpMargin;
tmpMargin := tmpMargin+chrtSavingsNeeded.Canvas.TextHeight(Text);
chrtSavingsNeeded.Axes.Bottom.Title.Visible:=false;
if chrtSavingsNeeded.Legend.Visible and (chrtSavingsNeeded.Legend.Alignment = laBottom) then
chrtSavingsNeeded.Legend.CustomPosition:=true;
chrtSavingsNeeded.Legend.Left:=(chrtSavingsNeeded.Width div 2) - (chrtSavingsNeeded.Legend.Width div 2);
tmpHeight:=chrtSavingsNeeded.Legend.Height;
chrtSavingsNeeded.Legend.Top:=chrtSavingsNeeded.Axes.Bottom.PosAxis+tmpMargin;
tmpMargin:=tmpMargin+tmpHeight;
chrtSavingsNeeded.MarginUnits:=muPixels;
chrtSavingsNeeded.MarginBottom:=tmpMargin;
procedure TForm1.Resize;
inherited;
RecalcBottomMargin;
Posted: Thu Oct 16, 2014 8:25 pm
by 10546565
Thank you for your responses.
If I use the Footer.Text property for my charts sub-title, the overlap still occurs. (I tried to change the code you wrote but could not get it to work with my new demo).
Ed Dressel
Posted: Fri Oct 17, 2014 8:34 am
by narcis
Hi Ed,
With the
modifications David Berneda made to the code it's working fine now:
- EdDresselCaptions.jpg (21.34 KiB) Viewed 15998 times
So you may expect this being fixed in the next maintenance release. If you are interested, you can also check David's new beta version
here.
Posted: Fri Oct 17, 2014 2:49 pm
by 10546565
It's difficult to release beta code to my end users--it doesn't go over very well when it doesn't work. How close is this to being a final release?
Posted: Mon Oct 20, 2014 6:59 am
by narcis
Hello Ed,
TestAlways wrote:How close is this to being a final release?
We expect this version being out in about one month.
