Exception on opening form with component using TChart
Collinor
Post by Collinor » Fri Jul 25, 2014 6:50 am
TeeChart 2014: If I write a component which is a descendant of TPanel and which creates a TChart in the constructor with owner being Self, then any form on which my component was/is put cannot be opened in the Delphi IDE (design time), since an exception (translated from German):
access violation at address 504F0554 in module vcl200.bpl. reading address 00000000
is thrown. The exception is not thrown at run-time.
If I pass nil or the panel's owner as owner to TChart.Create everything is fine.
Here's an outline of the component:
interface
type
  TCollChartPanel = class(TPanel)
  private
    FChart           : TChart;
  public
    constructor Create(Owner : TComponent); override;
procedure Register;
implementation
constructor TCollChartPanel.Create(Owner : TComponent);
  inherited;
  Self.Parent      := Owner as TWinControl;
  Self.BevelOuter  := bvNone;
  Self.BevelInner  := bvNone;
  Self.BorderStyle := bsNone;
  FChart        := TChart.Create(Self); // nil or Owner works fine
  FChart.Parent := Self;
  FChart.Align  := alClient;
procedure Register;
  RegisterComponents('Collinor', [TCollChartPanel]);
Re: Exception on opening form with component using TChart
Post by Sandra » Tue Jul 29, 2014 9:51 am
Hello Collinor,
Thanks for your information. Could you please arrange for us a simple applications with your own component, because we can check if the exception occurs here and we try to find a solution for it?
Thanks in advance,
Collinor
Post by Collinor » Sun Aug 17, 2014 12:04 pm
With Delphi's menu entry Component/New Component... create a new component TCollChartPanel in unit CollChartPanel with the following code and put it in a new package with name Coll:
unit CollChartPanel;
interface
uses
  System.SysUtils, System.Classes, Vcl.Controls, Vcl.ExtCtrls, VCLTee.Chart;
type
  private
    { Private-Deklarationen }
    FChart           : TChart;
  protected
    { Protected-Deklarationen }
  public
    { Public-Deklarationen }
  published
    { Published-Deklarationen }
procedure Register;
implementation
uses
  Forms; // bsNone
procedure Register;
  RegisterComponents('Samples', [TCollChartPanel]);
  inherited;
end.
Compile the Coll package and install it.
Then, create a new VCL application, put the CollChartPanel component (found in the Samples tool palette) on the main form and save and close the project.
Now reopen the project and you'll see that an exception is raised and the main form won't open.
Next, open the Coll package again, and change the line
into
  FChart        := TChart.Create(Owner); // nil or Owner works fine
recompile the package and close the project.
Finally, reopen the VCL application with the TCollChartPanel component on the main form and you'll see that the main form will open without error.
Post by Yeray » Tue Aug 19, 2014 2:57 pm
This worked fine for me in Delphi 7.
testComponent.zip
(6.44 KiB) Downloaded 783 times
I'll try it with XE6 and let you know asap.
Post by Yeray » Tue Aug 19, 2014 3:08 pm
Hello again,
It worked without problems for me also in XE6:
testComponentXE6.zip
(6.48 KiB) Downloaded 785 times
testColl.zip
(4.09 KiB) Downloaded 782 times
I'm using TeeChart v2014.11, and you?
Post by Yeray » Tue Aug 19, 2014 3:11 pm
Sorry, I missed the last part:
Collinor wrote:Now reopen the project and you'll see that an exception is raised and the main form won't open.
I've reproduced the problem now.
We'll investigate it and let you know asap.
Post by Yeray » Wed Aug 20, 2014 8:53 am
I've created a ticket in the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=893
