The the attached demo, two TChartShape series are used to create the green area below. But I need a shape that will fill in the dotted area (dotted lines added with an editor) with green.
Can that be done?
I've attached a simple demo of the app.
Thank you,
Ed Dressel
Custom Chart Shape
- Advanced
Custom Chart Shape
- Shape Series.rar
- (1.58 KiB) Downloaded 498 times
Re: Custom Chart Shape
Hi Ed,
I can think on two alternatives.
1. Use a third TChartShape, with chasInvertTriangle Style. The problem here is that you'll be drawing a shape bigger than the area you highlighted. In this case it works, but won't work as you wish in a different situation.
2. Manually draw your shape at OnAfterDraw event. Ie:
lSrs := TChartShape.Create(self);
lSrs.ParentChart := Chart1;
lSrs.Style := chasInvertTriangle;
lSrs.SeriesColor := clGreen;
lSrs.Pen.Visible := false;
lSrs.X0 := 23;
lSrs.X1 := 37;
lSrs.Y0 := 15;
lSrs.Y1 := 25;
var points: array of TPoint;
setLength(points, 3);
with Chart1.Axes do
points[0]:=Point(Bottom.CalcPosValue(23), Left.CalcPosValue(25));
points[1]:=Point(Bottom.CalcPosValue(30), Left.CalcPosValue(25));
points[2]:=Point(Bottom.CalcPosValue(30), Left.CalcPosValue(15));
with Chart1.Canvas do
Pen.Style:=psClear;
Brush.Style:=bsSolid;
Brush.Color:=clGreen;
Polygon(points);
