2014 reduced performance with back image
Posted: Wed Apr 16, 2014 9:01 pm
by 10046032
I am using the latest 2014 32 bit VCL with Delphi XE (Windows 7 64 bit) and I noticed that with GDI+ when a back image is defined, the chart slowly redraws (e.g. pan and zoom are slow). If I use the GDI canvas then performance is ok. Does anyone noticed this behavior? Is there a work around? I did try setting back image draw quality to low but this does not help.
Kindest regards
Re: 2014 reduced performance with back image
Posted: Thu Apr 17, 2014 9:25 am
by 16567921
Ok, here is what I found by mistake :) After adding a filter to the back image performance looks normal. Attached is a sample project (also notice that the unfiltered image is not displayed correctly)
Posted: Thu Apr 17, 2014 12:23 pm
by narcis
Thanks for the example project.
I could reproduce both problems here using the latest binary version but they are solves with our current sources:
I can send you a test version so that you can test if it solves the problem at your end.
Posted: Thu Apr 17, 2014 1:35 pm
by 16567921
Hello Narcis,
I can confirm that the test version solves the issue!!! Thank you very much for your prompt reply and support :)
Kindest regards
Posted: Thu Apr 17, 2014 1:37 pm
by narcis
Hi johnnix,
You're very welcome! I'm glad to hear that.
