Hiding line pen broken in Build 2013.09.131119
hansw
Post by hansw » Wed Nov 27, 2013 9:52 am
we are using TLineSeries in a situation where we decide after the creation of the series if the line should be visible or not.
Until the last build we were able to hide the line by setting Series->LinePen->Visible = false.
Now this setting does not have an affect any more (only the symbol in the legend becomes larger).
Is this a bug or desired behavior?
Thanks in advance for an answer,
regards
Hans
Re: Hiding line pen broken in Build 2013.09.131119
Post by Narcís » Wed Nov 27, 2013 11:34 am
Hello Hans,
This looks like a bug. Could you please add it to bugzilla? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
hansw
Post by hansw » Wed Nov 27, 2013 12:22 pm
Hello Narcís,
reported as bug 486 (http://bugs.teechart.net/show_bug.cgi?id=486).
Hans
Post by Narcís » Wed Nov 27, 2013 12:25 pm
Thanks Hans, confirmed!
Post by Narcís » Wed Nov 27, 2013 1:02 pm
Hello Hans,
Also, as a workaround, you can disable series at Chart -> Series or at run-time setting the Active or Visible properties to false:
  Series1.Active:=False;
hansw
Post by hansw » Wed Nov 27, 2013 1:09 pm
Hello Narcís,
Narcís wrote: Also, as a workaround, you can disable series at Chart -> Series or at run-time setting the Active or Visible properties to false:
I'm sorry, this won't work because I want to hide the line only, the points should still be visible. It's like switching from TLineSeries to TPointSeries.
Hans
Post by Narcís » Thu Nov 28, 2013 1:40 pm
Hello Hans,
This has just been fixed. I sent you the unit with the fix.
Valgardur Gudjonsson
Post by Valgardur Gudjonsson » Thu Mar 23, 2017 1:14 pm
Hi, this seems to be a problem in Delphi 10.1 Berlin, update 2 - TeeChart Pro VCL FMX 2016.19.
Updating (very) old code, and setting LinePen.Visible to False, makes no difference, temporarily I can use .Active - but not as a permanent method.
Post by Yeray » Fri Mar 24, 2017 3:18 pm
As you can see in the comments #486:
David wrote:Automatically forcing the 2D line to paint, is done now only when the series Pointer and DrawArea aren't painted.
Is this your situation?
Why can't you use Active property at long term?
