LineBreaks on TopAxis Items
Posted: Mon Oct 14, 2013 10:41 am
by 16567478
After upgrading from version 8.07 to 2013 I'm getting a error in the TopAxis items.
If I add an Item with the following code:
AChart.TopAxis.Items.Add(Position, 'ABC' + TeeLineSeparator + 'DEF' + TeeLineSeparator + 'GHI');
Then DEF comes two lines below ABC (one emty line between) and one character to the right. (D is coming under B and E under C).
GHI is coming exactly under DEF as it should!
Is this a new feature?
Best regards, Mikael
Re: LineBreaks on TopAxis Items
Posted: Mon Oct 14, 2013 1:58 pm
Hi Mikael,
I've tried the following code:
uses Series;
Chart1.MarginBottom:=12;
Chart1.AddSeries(TPointSeries).FillSampleValues(10);
Chart1.Axes.Bottom.SetMinMax(0,9);
Chart1.Axes.Bottom.Items.Add(5, 'ABC' + TeeLineSeparator + 'DEF' + TeeLineSeparator + 'GHI');
This is how it looks with v2013.08:
- v2013.08.png (7 KiB) Viewed 9774 times
And this is how the same example looks with the actual sources (and with the
beta) we have here:
- actual.png (9.61 KiB) Viewed 9781 times
So it should be fixed with the next maintenance release.
Posted: Mon Oct 14, 2013 2:59 pm
by 16567478
Ok, great!
Do you have an estimate when it will be released?
I was supposed to deliver today
Posted: Mon Oct 14, 2013 3:35 pm
Hi Mikael,
I'm afraid I can't tell you when the next release will be published. In the meanwhile you can use the beta version if it's fine for you.
Posted: Mon Oct 14, 2013 5:35 pm
by 16567478
Ok, but where can I find this Beta? I checked under Customers downloads and I can only find the Betas below:
TeeChart2013SourceCode.exe
April 30, 2013
Build 2013.08.130430 BETA
TeeChart2013RADXE4.exe
April 30, 2013
They are both older than the source code Beta that I'm using:
May 21, 2013
Build 2013.08.130521
Posted: Tue Oct 15, 2013 7:09 am
Hi Mikael,
I wrote the link above:
Yeray wrote:with the
beta
Here you have the direct link to the zip:
http://alturl.com/bxtdr
