Recompile error
Posted: Fri Mar 15, 2013 12:05 pm
by 10545848
I'm trying to run the recompile program to build XE3 32 and 64 bit. When I do I get the following error...
Why is it looking in TeeChart Pro 8.08 Full Source Code..... directory? Do I need to install version 8.08 code first?
TeeChart Pro
Compilation started: 3/15/2013 7:58:00 AM
RAD XE3.Win32 v17 (RAD XE v10 Professional)
EXCEPTION:
Cannot copy file: D:\Program Files (x86)\Steema Software\TeeChart Pro 8.08 Full Source Code\Sources\FMXTee.Chart3D.pas to D:\Program Files (x86)\Steema Software\TeeChart Pro 8.08 Full Source Code\Sources\FMX\FMXTee.Chart3D.pas
Error Code: 2 Description: The system cannot find the file specified
Re: Recompile error
Posted: Fri Mar 15, 2013 3:26 pm
by 10050769
Hello dpatch,
I am afraid that TeeChart Pro 8.08 isn't supported by RAD XE3, RADXE2 and RADXE as you can check in next threads:
http://www.teechart.net/support/viewtop ... 83&p=57283
http://www.teechart.net/support/viewtop ... 147#p52147
http://www.teechart.net/support/viewtop ... 615#p49573
Moreover, If you are interesting you can do something as do the client in this
link with version 7. But if you want work with XE3 without problems, I recommend you upgrade to the actual version.
Re: Recompile error
Posted: Fri Mar 15, 2013 5:22 pm
by 10545848
Please read my initial post carefully before you respond as our time zones are very different and I will have to wait another full day.
I did upgrade to Tee Chart v2012.07.121105 and I installed the binaries but they do not include 64 bit so I am trying to recompile the source code. I am running the recompile application that shipped with TeeChart2012SourceCode.exe and that application is what is looking for version 8.08 code when I select only the XE3 32 and 64 bit checkboxes. The error is real since I DO NOT install Tee Chart version 8.08 source code.
Why is it looking for version 8.08 code?
Re: Recompile error
Posted: Mon Mar 18, 2013 10:55 am
by 10050769
Hello dpatch,
First, I inform you that the TeeChartVCL (v2012.07.121105) included x32 and x64 bits. I check it here and appears x64 bits as you can see in next image:
- BinaryInstallation.jpg (102.91 KiB) Viewed 10433 times
Is possible your path are incorrect, because using last version of TeeChartVCL (v2012.07.121105) source code I haven't found any problems. Please following next steps to try to solve the problem:
1.- Install the last version of TeeChartVCL Source Code v2012.07.121105.
2.- Open Teerecompile as included in this version.
3.- Check your path is correct, you should have a similar path:
C:\Program Files\Steema Software\TeeChart Pro 2012 Full Source Code\Sources
If you have a different path please, change it.
4.- Selected option to compile RAD XE3.Win64 v17 Architect (RAD XE v10 Architect) (C++) and click begin.
Can you tell us if previous steps help you to solve the problem?
Re: Recompile error
Posted: Tue Mar 19, 2013 12:41 pm
by 10545848
Yes, this issue can be closed...Thank you.
The problem was the path in your list numbered 3. It was pointing to TeeChart Pro 8.08 Full Source Code instead of 2012. I suspect this is a bug in the installation program for the 2012 version since I never installed the source code for 8.08
Thanks again!
Re: Recompile error
Posted: Tue Mar 19, 2013 3:18 pm
by 10050769
Hello dpatch,
I am glad that you have been solved your problem
