TeeChart2011 PreReleaseXE TeeRecompile error
I can't start TeeRecompile, the error is:
Can't start as FastMM_FullDebugMode.dll is absent
- Site Admin
- Contact:
Re: TeeChart2011 PreReleaseXE TeeRecompile error
Hi vlezhu,
Thanks for reporting. We will investigate the issue. In the meantime you can download FastMM files at http://sourceforge.net/projects/fastmm/
But after FastMM install:
Cannot recompile C++ Builder package: TeeMaker1C6.mak
MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
D:\Cbuild6\bin\..\BIN\bcc32 -O2 -H=D:\Cbuild6\bin\..\lib\vcl60.csm -Hc -Vx -Ve -X- -a8 -6 -b- -k- -vi -c -tWM -w-par -I;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D;NO_STRICT;_RTLDLL;USEPACKAGES -n.\ .\TeeMaker1C6.CPP
Borland C++ 5.6.4 for Win32 Copyright (c) 1993, 2002 Borland
.\TeeMaker1C6.cpp:
Loaded pre-compiled headers.
D:\Cbuild6\bin\..\BIN\dcc32 -$Y- -$L- -$D- -$A8 -Q -v -JPHNE -M -U;PNGImage;..\..\Sources9 -U;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D;NO_STRICT;_RTLDLL;USEPACKAGES -O;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl --BCB .\TeeBlocks.PAS
Borland Delphi Version 14.0
Copyright (c) 1983,2002 Borland Software Corporation
13561 lines, 0.25 seconds, 106475 bytes code, 54 bytes data.
D:\Cbuild6\bin\..\BIN\dcc32 -$Y- -$L- -$D- -$A8 -Q -v -JPHNE -M -U;PNGImage;..\..\Sources9 -U;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D;NO_STRICT;_RTLDLL;USEPACKAGES -O;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl --BCB .\TeeMakerEditor.PAS .\TeeChart3D.PAS
6648 lines, 1.03 seconds, 1523 bytes code, 4 bytes data.
D:\Cbuild6\bin\..\BIN\ilink32 @MAKE0000.@@@
Turbo Incremental Link 5.64 Copyright (c) 1997-2002 Borland
Fatal: Unable to open file 'BASS.LIB'
** error 2 ** deleting TeeMaker1C6.bpl
.\TeeMaker1C6.cpp:
- Site Admin
- Contact:
Hi vlezhu,
What about disabling Tee 3D packages on the top-right and compile again?
After disabling Tee3D:
Cannot recompile C++ Builder package: TeeTree2C6Tee9.mak
D:\Cbuild6\bin\..\BIN\bcc32 -Od -H=D:\Cbuild6\bin\..\lib\vcl60.csm -Hc -Vx -Ve -X- -r- -a8 -b- -k -y -v -vi- -c -tWM -w-par -Ic:\Program Files\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\Compiled\Builder6\Include;c:\Program Files\Steema Software\TeeChart Pro 2011 Full Source Code\Sources\..\TeeTree\Sources9\Compiled\Builder6\Include;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl -D_DEBUG;_RTLDLL;NO_STRICT;USEPACKAGES -n.\ .\TeeTree2C6Tee9.cpp
Error E2194: Could not find file 'Files\Steema.cpp'
Error E2194: Could not find file 'Software\TeeChart.cpp'
Error E2194: Could not find file 'Pro.cpp'
Error E2194: Could not find file '2011.cpp'
Error E2194: Could not find file 'Full.cpp'
Error E2194: Could not find file 'Source.cpp'
Error E2194: Could not find file 'Code\Sources\Compiled\Builder6\Include;c:\Program.cpp'
Error E2194: Could not find file 'Code\Sources\..\TeeTree\Sources9\Compiled\Builder6\Include;D:\Cbuild6\bin\..\include;D:\Cbuild6\bin\..\include\vcl.cpp'
.\TeeTree2C6Tee9.cpp:
EXCEPTION:
Compilation aborted.
EXCEPTION:
- Site Admin
- Contact:
Hi vlezhu,
And disabling TeeTree packages as well?
But disabling TeeTree packages will help, as TeePro file now were gotten, this error was in the April realease, as I remember and I had to use binary installer
- Site Admin
- Contact:
Hi vlezhu,
Yes, I checked that and I added the issue (TV52015776) to the bug-list to be fixed as soon as possible.
Regarding the FastMM files issue, you shouldn't need them, they should only be used in-house. We will try to fix this as well.
- Site Admin
- Contact:
Hi vlezhu,
Find attached updated TeeRecompile version. Can you please check if this solves the FastMM issues at your end?
- TeeRecompile.zip
- (392.75 KiB) Downloaded 948 times
Hi Narcís
No, this TeeRecompile gave me the same error, can't start without FastMM
- Site Admin
- Contact:
Hi vlezhu,
Can you please try this version? I checked it works fine for me here.
- TeeRecompile.zip
- (462.37 KiB) Downloaded 940 times
I tested the latest, but have the same error, I am working on Win7-32 Russion locale, may be this is the reason? If I'put fastMM dll to the same directory I can start TeeRecompile
- Site Admin
- Contact:
Hi vlezhu,
Can you please try with this new TeeRecompile version?
- TeeRecompile.zip
- (462.95 KiB) Downloaded 929 times
No, does not work again, I've just tested on my home PC with Win7-32 and got the same error.
If I'll copy FastMM.dll, teerecompile will start fine.
The previous version I've tested in my office's PC
Both computers have Win7-32 and RadStudioXE and CBuilder6.
Vladimir (vlezhu).
Vladimir (vlezhu).
Hello Vladimir,
We haven't forgotten you. We will probably publish a new PreRelease version as soon as we'll solve some problems we've identified.
