c++builder How to prohibit dragging legends
How to prohibit dragging legends?
Re: c++builder How to prohibit dragging legends
I don't understand what do you mean. The legend isn't draggable by default.
Could you please expand?
Why is it possible to drag by default?
How to prevent the legend from being dragged?
- 1122.png (11.86 KiB) Viewed 24342 times
Check the code and the form in your project.
Sorry but it should not be draggable by default.
I found the reason。
I added a selection tool to achieve drag and drop annotation functionality。
This causes the legend to also be dragged. How to solve this problem???
- 444.png (7.09 KiB) Viewed 24300 times
- 334455.png (13.83 KiB) Viewed 24300 times
Does anyone answer my question???
Indeed, the
So, instead of having a
Indeed, the
TAnnotationTool
doesn't support dragging. However, the TRectangleTool
does.So, instead of having a
TAnnotationTool
and adding a TSelectorTool
to add dragging support to it, you could just use a TRectangleTool
.Best Regards,
Due to requirements, I can only use Annotation. How can I prevent dragging legends?
Please provide a demo of c++builder。
You can't make the
You can't make the
TSelectorTool
not to detect the Legend. So, instead of using the TSelectorTool
, I'd implement the TAnnotationTool
dragging myself.Code: Select all
#include <VclTee.Chart.hpp>
#include <VclTee.Series.hpp>
#include <VclTee.TeeTools.hpp>
private: // User declarations
TChart* Chart1;
TAnnotationTool* Annotation;
TPoint* annotationOffset;
bool annotationDragging;
void __fastcall ChartMouseDown(TObject *Sender, TMouseButton Button,
TShiftState Shift, int X, int Y);
void __fastcall ChartMouseMove(TObject *Sender, TShiftState Shift,
int X, int Y);
void __fastcall ChartMouseUp(TObject *Sender, TMouseButton Button,
void __fastcall TForm1::FormCreate(TObject *Sender)
Chart1 = new TChart(this);
Chart1->Parent = this;
Chart1->Align = alClient;
Chart1->Color = clWhite;
Chart1->Gradient->Visible = False;
Chart1->Walls->Back->Color = clWhite;
Chart1->Walls->Back->Gradient->Visible = False;
Chart1->View3D = False;
for (int i=0; i < 2; i++) {
TFastLineSeries* fastLine = new TFastLineSeries(this);
Chart1->AddSeries(fastLine);
fastLine->FillSampleValues();
Annotation = new TAnnotationTool(this);
Chart1->Tools->Add(Annotation);
Annotation->Left = 100;
Annotation->Top = 100;
Annotation->Text = "Annotation tool";
Chart1->OnMouseDown = ChartMouseDown;
Chart1->OnMouseMove = ChartMouseMove;
Chart1->OnMouseUp = ChartMouseUp;
void __fastcall TForm1::ChartMouseDown(TObject *Sender, TMouseButton Button,
if (Annotation->Clicked(X,Y))
annotationDragging = true;
annotationOffset = new TPoint(X-Annotation->Left,Y-Annotation->Top);
void __fastcall TForm1::ChartMouseMove(TObject *Sender, TShiftState Shift,
int X, int Y)
if ((!annotationDragging) and (Annotation->Clicked(X,Y)))
Chart1->Cursor = crHandPoint;
Chart1->CancelMouse = true;
if (annotationDragging)
Annotation->Left = X-annotationOffset->X;
Annotation->Top = Y-annotationOffset->Y;
void __fastcall TForm1::ChartMouseUp(TObject *Sender, TMouseButton Button,
Chart1->Zoom->Active = false;
annotationDragging = false;
How to obtain a legend pointer for the Chart1MouseUp function???
You can access the Legend with
Chart1->Legend
. Ie:Code: Select all
Chart1->Legend->Color = clRed;
How to determine whether the selected item is a legend in the Chart1MouseUp function???
You can check if the
Legend
is in a given position with the Clicked
function. Ie:Code: Select all
if (Chart1->Legend->Clicked(X, Y) > -1)
Chart1->Legend->Color = clWhite;
How to prevent the legend from being dragged during the chartmousemove event, as shown in the following example???
Sorry, in what example?wrote: ↑Tue Aug 08, 2023 1:22 amHow to prevent the legend from being dragged during the chartmousemove event, as shown in the following example???
