THistogramSeries % Bar Width
What does this property do? Setting it to 100% produces bars that overlap. The value I need to obtain non-overlapping bars is much less than this, but varies according to the zoom. What does 100% mean? There seems not to be any help for this class. I'm using in TeeChart Pro v2014.12.140923 32-bit VCL in XE7.
Toreba
Toreba
Re: THistogramSeries % Bar Width
Hello Toreba,
Could you please arrange a simple example project showing us what are you exactly doing?
Yeray,
I'm sorry, I was wrong (again). THistogramSeries works fine, and doesn't offer a % bar width property. It is In fact TBarSeries for which the property makes no sense. Do you agree with that?
Toreba
Toreba
Hello Toreba,
There are 3 properties with similar names that could be confusing you. From the online docs:
TCustomBarSeries.BarWidthPercent wrote:TCustomBarSeries.BarWidthPercent
TCustomBarSeries
property BarWidthPercent: Integer;
Unit
Series
Description
Default Value: 70
The BarWidthPercent property determines the percent of total Bar width used. Setting BarWidthPercent := 100 makes joined Bars. You can control how many Bars appear at same time by using TChart.MaxPointsPerPage property. The BarWidth and BarHeight properties indicate Bar dimensions in pixels.
TBarSeries.BarWidth wrote:TBarSeries.BarWidth
TBarSeries
property BarWidth: Integer;
Unit
Series
Description
Run time and read only. The BarWidth property returns the width of vertical Bars in pixels. Bar widths change at run-time when resizing or zooming the Chart. BarWidth is a read-only property. You can use the CustomBarWidth property to set a fixed pixels Bar width.
Which one doesn't behave as you'd expect?TBarSeries.CustomBarWidth wrote:TBarSeries.CustomBarWidth
TBarSeries
property CustomBarWidth: Integer;
Unit
Series
Description
Default: 0
The CustomBarWidth property determines the fixed Bar width in pixels. You can use the BarWidth property to get the current Bar width in pixels.
Yeray,
I think it's the first of these properties that doesn't work, at least using v2014.12.140923 32-bit in XE7. It's easy to show with a simple demo. Do you need me to provide one?
Toreba
Toreba
Hi toreba,
This is what I get with v2012.14 and the code below:
uses Series, TeeConst;
Chart1.Title.Text.Text:=TeeMsg_Version;
Chart1.View3D:=false;
FillSampleValues();
BarWidthPercent:=100;
Yeray,
Yes, I get the same, but see what happens when you zoom in. The bar width in pixels seems to remain unchanged, so then fills less than 100% of the gap between the adjacent bars either side. When you have a lot of points and zoom in a long way to the detail, the effect is at its worst. That's what I need to correct. Is there a combination of properties that would do that? Or is it a bug?
Toreba.
Toreba.
Hello Toreba,
Adding this, the BarWidthPercent property works better when zooming also:
AutoBarSize:=true;
We experience a similar problem for TBarSeries where the bar widths are not aligned according to the preset BarWidthPercent when the x-axis is not set to automatic, i.e. does not show all existing values in the series. See the image below.
The settings are:
We achieved this by adding some code to TBarSeries.DoBeforeDrawChart (I omitted some local procedures to make it easier readable):
We would appreciate if this or a similar functionality could be integrated into the standard code to make it available for other users.
Kind regards,
Linus
PS: I also attached a simple demo project containing the example above:
The settings are:
- BarWidthPercent set to 70%
- Bottom Axis with manual Minimum/Maximum, i.e. non-automatic mode. The intention is to display the values with respect to the current time (illustrated by the vertical ColorLineTool), i.e. it is a "moving window" where the axis bounds are frequently updated to focus the current time.
Procedure TCustomBarSeries.DoBeforeDrawChart;
var t : Integer;
Stop : Boolean;
tmp : Integer;
tmpNonMandatoryAxisRange : Double;
tmpValueStepPerBar: Double;
const cstAutoCalcBarPointsByBarSteps = True;
inherited;
IBarSize:=0;
IOrderPos:=1;
IPreviousCount:=0;
INumBars:=0;
IMaxBarPoints:=TeeAllValues;
Groups:=nil;
Stop:=False;
With ParentChart do
for t:=0 to SeriesCount-1 do
if Series[t].Active then
if SameClass(Series[t]) and SameMandatoryAxis(Series[t]) then
Stop:=Stop or (Series[t]=Self);
tmp:=Series[t].Count;
// ARC ///////////////////////////////////////////////////////////////////
// Calculate "visible" Bar Points based on their "step width" between two bars compared to visible axis range
if cstAutoCalcBarPointsByBarSteps and (NotMandatoryAxis.Automatic=False) then
tmpNonMandatoryAxisRange:=NotMandatoryAxis.Maximum-NotMandatoryAxis.Minimum;
if (tmp>1) and (tmpNonMandatoryAxisRange>0) then
tmpValueStepPerBar:=Series[t].NotMandatoryValueList.Range/(tmp-1); // -1 since we want the step BETWEEN two bars
tmp:=Round(tmpNonMandatoryAxisRange/tmpValueStepPerBar)+1; // +1 since the last bar also requires space
if (IMaxBarPoints=TeeAllValues) or (tmp>IMaxBarPoints) then
IMaxBarPoints:=tmp;
if FSideMargins and (tmp>0) then
Inc(IMaxBarPoints);
Case FMultiBar of
mbNone: INumBars:=1;
mbSide,
mbSideAll,
mbSelfStack:
Inc(INumBars);
if not Stop then Inc(IOrderPos);
mbStacked,
mbStacked100: if NewGroup(TCustomBarSeries(Series[t]).FStackGroup) then
Inc(INumBars);
if not Stop then
Inc(IPreviousCount,tmp);
for t:=0 to Length(Groups)-1 do
if Groups[t]=FStackGroup then
IOrderPos:=t+1;
break;
Groups:=nil;
if INumBars=0 then
INumBars:=1;
{ this should be after calculating INumBars }
if FMultiBar=mbSelfStack then
if ParentChart.MaxPointsPerPage=0 then
IMaxBarPoints:=INumBars
IMaxBarPoints:=ParentChart.MaxPointsPerPage
if ParentChart.MaxPointsPerPage>0 then
IMaxBarPoints:=ParentChart.MaxPointsPerPage;
if (ParentChart.MaxPointsPerPage>0) and FSideMargins and (IMaxBarPoints>0) then
Inc(IMaxBarPoints);
Kind regards,
Linus
Hello Linus,
That looks useful, thank you for the contribution. We'll run a few checks and include it in the product code.
Thanks again.
Thanks again.
Hello Marc,
thanks for the prompt and positive feedback. Happy to contribute - and after all, we're of course very interested to use the standard code base without having to merge any customisations of ours when installing a TeeChart update ...
Have a nice weekend,
Linus
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Linus
